Reply 20 of 53, by boxpressed
It looks like I will need another three-pin connector for the SDRAM headers. Luckily, this case has another three-pin connector that goes to the LED display. Because I'm fine leaving the display at 550, I'll just replace it with a regular jumper. Unfortunately, I may have to take the mobo out of the case to access the panel, so I won't be able to test for a while. Turns out that this particular case--with a pair of three pin connectors wired to the turbo button--might be the perfect one for building an all-in-one.
Reply 21 of 53, by alexanrs
Can you post the full table? Honestly, you shouldn't need to change jumpers. Usually their only purpose is to set the RAM to the same clock as the AGP bus if you wanna use PC-66 modules with the FSB set at higher clocks.
Reply 22 of 53, by boxpressed
Sure, here you go. The computer wouldn't post with the FSB set to 66MHz and the SDRAM set to 100MHz. Are you thinking I can set the SDRAM to 66MHz and still run the FSB at 100MHz?
Reply 23 of 53, by alexanrs
I'd guess CLK4 locks the SDRAM to the AGP clock speed, but I can't really guess what SDRAM2 does. You'd need to look at the datasheet of the chipset probably. If you can make the cables, though, it is probably the safer approach.
Reply 24 of 53, by boxpressed
I'm hopeful that I can get it to work with the pair of three-pin connectors already attached to the Turbo button. It would have been kind of nice to have the LED read out "100" or "66," though. If anyone knows of a source for a turbo switch with three wires and a three-pin connector, I'm all ears.
Reply 26 of 53, by squareguy
Scored two Dell 2001FP monitors today without power adapters. Ordering some now. I think this might be the best option for a monitor in 4:3 format. I sure hope they both work! I will probably connect the Quadro4 380 XGL to the DVI input and the Voodoo 2's to the VGA input and do without the VGA-passthrough cable.
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 27 of 53, by boxpressed
@alexanrs Will do. Will report back soon.
@squareguy That's my regular, everyday monitor. I bought it new back in 2004 or so. It's great in general, but mine will leave ghost images if it has displayed the same image for a long time. Great 1600x1200 resolution. I connect it to my notebook via an DVI-to-HDMI adapter. If you're not too picky about speaker quality, add a matching Dell soundbar to it.
Reply 28 of 53, by squareguy
@boxpressed
very nice. I am very picky about sound quality though 🙁 it makes life harder. I will be using headphones and I am building a new headphone amplifier now.
Windows 98 SE
Reply 29 of 53, by squareguy
Ok maybe not harder.... but definitely more expensive.
Windows 98 SE
Reply 30 of 53, by boxpressed
alexanrs wrote:
For now, try setting it to the default (66MHz as a non-PC 100 module) and see if it POSTs at 100MHz FSB.
Unfortunately, still no POST if the FSB & memory frequencies do not match. I set the jumpers to the default setting, and it will POST only when the FSB is set to 66MHz.
Reply 31 of 53, by squareguy
can it only run SDRAM 2 and 3 asynchronously? Like SDRAM 1 has to run at the FSB but the other two dont?
Windows 98 SE
Reply 32 of 53, by brostenen
GeorgeMan wrote:
I'm curious how did you manage to set that "550" on the LED display!
I haven't even heared of a full 3 digit LED display for that purpose.
I have an AT-Case with 3-digit LED display too...
Reply 33 of 53, by GeorgeMan
Yeah I had a full AT tower with it also, but it's the only pc I've ever seen live featuring 3digit led display.
Core i7-13700 | 32G DDR4 | Biostar B760M | Nvidia RTX 3060 | 32" AOC 75Hz IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 34 of 53, by alexanrs
You might not be able to escape using the other cable then. I'm still curious as to why.
I had an ATX case with a three digit LED display. It was my Pentium 3 700MHz
Reply 35 of 53, by boxpressed
The cable from the other three-pin header is too short to reach the SDRAM header. Even I would be able to splice in an extension, but I'm in no hurry and would rather not cut up the original wiring. I just ordered some single-pin male-female extension cables, and I'll test next week.
Reply 36 of 53, by squareguy
I am thinking about a logo sticker for the case. Just goofing off, I came up with this. I need a better A3D image to work with if anyone knows where one is. I am a crappy artist so if anyone has some ideas let me know.
233.26 KiB
Windows 98 SE
Reply 37 of 53, by squareguy
Quick and dirty, maybe something like this all cleaned up?
100.75 KiB
Windows 98 SE
Reply 38 of 53, by squareguy
Getting better maybe, not there yet.
94.18 KiB
Windows 98 SE
