First post, by Shoal
Shoal
Offline
Hi all.
I'm using DOSBox 0.62, and supposedly TIE Fighter is supposed to run fine in it. However, it doesn't - sound effects don't play (but MIDI music does), and cutscenes don't function.
I know I've set up the sound correctly; it even plays during the test function in the installer. As for cutscenes, no one mentioned anything about ANY problems on the DOSBox compatibility list.
I run the game at 15,000 CPU cycles, and have a bleeding edge computer system. Any help would be greatly appreciated.
Thanks,
Shoal
