First post, by mrthaggar
Hello everyone, hope someone can help me out.
I'm trying to install Broken Sword 1 onto my Win xp machine, but when I run the setup I get the following error:
"Could not install Directx Error Code -9"
Microsoft give a solution for this here, but the files it mentions are not on my system.
http://support.microsoft.com/default.aspx?sci … &NoWebContent=1
Hope someone can help.
Thanks in advance.
Tony
Reply 1 of 3, by Dark Knight ez
Try scummvm. (www.scummvm.org)
It should be able to run Broken Sword 1.
... // bda. very bda!
... // but only if you turn godo into csah.
Reply 2 of 3, by Jumjalum
Yep use ScummVM and it should run ok, check the multi-cd section of the readme for directions on installing.
Reply 3 of 3, by Janeus
I got the game working on xp a few weeks ago without using scummVM. all i did was mess around with the compadibility options for the install exe
