DOS only drivers for esstech pci soundcards
Postby tikbalang » 2008-8-07 @ 02:48
esstech installers need win9x to install. here are some i have tested under DOS.
http://www.mediafire.com/?xedx9bygyb6
Code: Select all
essdos.zip
a collection of esstech pci soundcard drivers for DOS.
es1938 ESS 1938/41/46 Solo-1 AudioDrive (16bit)
es1941 ESS 1938/41/46 Solo-1 AudioDrive (16bit)
es1946 ESS 1938/41/46 Solo-1 AudioDrive (16bit)
es1968 ESS 1968 Maestro-2 AudioDrive (16bit)
es1978 ESS 1978 Maestro AudioDrive (16bit)
es1980 ESS 1980 Maestro-3 AudioDrive (16bit)
es1989 ESS 1989 Allegro-1 AudioDrive (16bit)
ripped from:
ESS Technology (http://www.esstech.com)
config.sys
DEVICEHIGH=C:\ESS*****.SYS
autoexec.bat
LH C:\ESS*****.COM
ESSDOS.zip
essdos.zip
*** more ***
(111.85 KiB) Downloaded 2152 times
User avatar
tikbalang
Re: DOS only drivers for esstech pci soundcards
Postby Niezgodka » 2015-9-30 @ 23:47
Does not work for my DOS ess 1978 :(
User avatar
Niezgodka
Postby collector » 2015-9-30 @ 23:53
This forum is for DOS games not hardware and its drivers. All old hardware, drivers and its configuration should be asked in Marvin.
User avatar
collector
Postby Stiletto » 2015-10-01 @ 00:12
Moved.
Niezgodka, please knock it off with the bumping ancient threads, thanks. :)
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby Windows9566 » 2017-8-19 @ 21:43
Its too quiet for me, i can barely hear the fm synth and can somewhat hear the digitized sound
Windows9566
Postby dr.zeissler » 2017-8-19 @ 22:41
try "essvol" in your autoexec.bat
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Who is online
Users browsing this forum: oerk, xjas and 8 guests
