kreats wrote:Did you download it from archive.org or somewhere else? Someone might have fixed it and offered it as part of a set to download.
It's been a long time, but I don't remember ever downloading these from anywhere except archive.org.
I think what probably happened is that I (or maybe my brother) edited out the last ~20 seconds where the audio glitches, and re-encoded the resulting 28m:02s version as a new .mpg file in TMPGEnc. I don't know what tool would have been used for the actual editing, but I was using TMPGEnc to encode MPEG-2 files back then. Apparently my settings caused it to make a smaller file size than the original. I don't remember for certain, but that's likely what happened. If you have the original 2GB file then I'd try doing a similar edit and see if it works.
kreats wrote:Attached is a rar with screenshots of what I get when I go to codec information in VLC - there seems to be an abnormal amount of tracks? I checked playback with VLC and it indeed plays with no audio.
That does look pretty messed up. Mine is just like this:
The attachment Clipboard01.png is no longer available
and as mentioned, mine cuts out the last ~20-30 seconds, just about exactly where the audio goes mute on the embedded web player on the archive.org site. I think there must be a glitch at that point which was removed to fix the file.
