First post, by TELEPACMAN
- Member
Here is another project of mine, you can have some idea as how the cards are installed inside.
I have a card in the AGP slot, then an empty space
a card in a pci slot, then an empty space
another pci card
then an empty space that in this mboard corresponds to the shared pci/isa slot
and finally a ISA card and the last empty space.
I did this to have a good airflow, but is there a better way to install your cards? Does it affect performance or it doesn' t matter?
Thank you.
