First post, by kekko
The game runs well, but if I press an arrow key too long (more than 1 sec) the game slows down until I release the key. this is a bit bothering in a flight simulator. It seems to be a kind of keyboard buffer overflow....
Apparently any dosbox version does it. I use dynamic core on an athlon xp and win 2000.
Reply 1 of 5, by kekko
so anyone had similar problems?
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
what if you don't use the dynamic core ?
Water flows down the stream
Reply 3 of 5, by kekko
the game is quite heavy, even on a 3ghz at full cpu cycles. It would be totally unplayable with "normal" core. at that point i would prefer slowdowns.
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
well dynamic core can sometimes cause slowdown if many irq are generated. You might want to try it again with the upcoming next version as that one has some different key repeat. Maybe that will benifit your cause.
Reply 5 of 5, by kekko
ok, thanks for the reply; i'll check next cvs.
