First post, by Guest
So, this is my problem. I'm running TR1 with Glidos and VDM on XP. I open glidos and start tr1, and all is well. Just as the CORE movie finishes, i pop back to windows briefly (with the glidos box in white), then back to the game. Each movie is cut off similarly, eventually leading to a crash once it happens enough (crashed once on the third movie, once on the fourth after starting a new game). That thing about removing a line from the .ini file didn't do jack. I'm using an ATI Radeon 9600 if that matters. Thanks for any help you can give me!
