First post, by Migs
I got carmageddon working with glidos 1.28, also have the latest VDM sound, when I run the VDM shortcut of CARMAV.EXE (with Glidos server running in background, but NOT started through glidos) I can get network, however the game is jittery and very unplayable. When I run it through Glidos, the game runs very smoothly, but I am unable to do any network games, I know it is nothing to do with my network setup because It works fine w/o using glide, and the network works just fine.
One thing I will point out, is that in the VDM shortcut, I have enabled the option in compatibility 'Use Low-Level Network Support' and that seems the be what is making the network work. Is there a command line for dosdrv that might give the same option of the low level network that I might be able to add it to glidos' setup for running the game? or is there a way to get it so that it's not so jittery when I play through the shortcut?
Thanks in advance.
Also I have tried to enable the option of basic VESA emulation and it doesn't help.
Reply 1 of 1, by Guest
The jitters are because that way of running will lose Glidos's PIT emulation. I can't think of a way around the problem at the moment.
