First post, by gumpy
- Newbie
I'm have trouble with Amazon by Telarium. Apparently, the game is set up to save on floppy disks and doesn't save or restore a game properly from DOSBOX.
There is a patch floating around on the internet so you can save the game to drive C, but then the patch messes up the game so you can't complete it. When you first arrive in the Amazon, you need to log on to your computer with a certain code number (969) - but with the patch installed, the correct code is considered to be incorrect and you can't proceed.
