DOSBox Uninstaller
First post, by Tiger433
Why DOSBox don`t have uninstaller program ? I don`t like deleting it everywhere after using it.
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 2 of 7, by Tiger433
I don`t use DOSBox much and sometimes when I do some testing on my second machine is good to uninstall it when I don`t use that no more there.
My Youtube channel
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
It comes with an uninstaller. It is in the startmenu
Water flows down the stream
Reply 4 of 7, by Tiger433
Sorry, now I found that, but that`s little hidden for me 😀
My Youtube channel
Reply 5 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Make yourself a cmd file that deletes both startmenu entry and the folder you normally install to.
What do youhave in mind? The uninstall entdy in the startmenu is perhaps the easiest (lowest number of mouseclicks).
Or you just don't delete it anymore from your secondary system. Honestly I don't get it. If it's always the ssme machine you install and delete it from, why not just leave it there? Dosbox os no security threat, doesn't slow down your computer (when not running 😉) and has a small footprint...
If you use it on several machines, a dedicated USB stick might be helpful
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 7, by Tiger433
I know, now I downloaded portable version of DOSBox from PortableApps.com, and I begin to use that from pendrive 😀 But I don`t see that option for years and I deleting program group, folder and shortcut all that time each time 🤣
My Youtube channel
Reply 7 of 7, by Dominus
DOSBox Moderator
PortableApps... *facepalm*
Reason why: you could have just copied dosbox from your primary machine. Dosbox is portable to begin with...
