First post, by ElBrunzy
- Oldbie
Hi, I'm a big fan of VOGONS, I spend alot of time at job reading forum threads just for the fun to remember how fun and easy it was back then ... At the end of the day I go crazy as those old computers are full of bugs and problems.
Anyway, I always feel like I should post more and contribute to this wonderfull web site, so here is my rig showdown :
First thing first, this is a pentium 200 (might be 233 downclocked to 200 to avoid the turbopascal bug). I changed all the fan for new one and put the cpu on 3.3 instead of 5 to make it more silent. As you see, it hold a GUSPNP with 8mb of ram. The OS is FreeDOS as the main drive is a 16gb fat32 compactflash. Can load usb drives from fdconfig.sys to copy files as the network from dos is so-so.
So here we have our big boy running windows 98 on the best video card it can run prior the os was abandoned buy drivers makers. It's a amd 6600 fanless. You can see there is a sblive under it and I found the APS drivers. Under dos7 there is no sb16 emulation (otherwise why not use dosbox) and about the sole program I can use is live amp player that play modules with the emu1000 chipset. On windows, I have a game of Manathan Project going on.
The dual pentium pro (256kb in SMP, I have a 512kb and 1024kb cpu, but only one ... if anyone have the pair?) it hold a gus classic with 1mb and a sb awe32 with 32mb (28really). I'm in the process to swap the hdd to cf, but it dont go really well. That computer host a true dos 6.22 os and ... up to now DamnSmallLinux maybe .. I dont know, I'm in the project of replacing win2000 as it cannot be helpfull on dual 8gb compactflash that cannot be seen as fixed drives.
any comments are welcome, as usual, it's always a pleasure to read you. Bye
