First post, by feipoa
I have finally jumped on the 486 VLB bandwagon and am in the process of maximising my "new" Asus VL/I-486SV2GX4. It will replace a setup in one of my cases (Biostar MB-8433UUD, Am5x86-160 w/GeForce2) and also use an Am5x86-160 w/1024K and 64 or 128 MB of RAM. I was going to buy another case, but shipping costs have become way high.
I have the following two VLB cards which I bought on eBay in 1999 and 2000 for next to nothing (are they valuable now?),
ATI Mach64 VLB wih 2 MB RAM
Diamond Stealth64 VRAM (aka Stealth Video 3000 series) VLB with S3 Vision968 and 4 MB RAM (it came with the memory add-on module)
I will be using the VLB graphics in combination with an Adpatec AHA-2842A SCSI controller. I also plan to run Windows 95 OSR 2.5.
Which card is preferred? Faster? Better? More glory?
Some good threads which cover VLB graphics are,
VLB Graphics recommendation
Fastest DOS VLB Graphics card ever?
I noticed that DOOM will not even begin on the Vision968 card if I leave LOCAL BUS READY set to TRANSPARENT in the BIOS. The transparent setting works fine on the Mach64 card and results in improved benchmark scores. Transparent option works fine on the Vision968 card, but only with the FSB set to 33 MHz; I am running the FSB at 40 MHz now. Anyone noticed this and discovered a means to correct for it?
DOS
DOOM(timedemo 3, realtics)
Stealth64 (synchronize) = 1135
Mach64 (synchronize) = 1278
Mach64 (transparent) = 1195
3DBench
Stealth64 (synchronize) = 90.9 fps
Mach64 (synchronize) = 83.3
Mach64 (transparent) = 90.9
PCPBench
Stealth64 (synchronize) = 11.3 fps
Mach64 (synchronize) = 11.4
Mach64 (transparent) = 11.6
PCPBench - VGA mode
Stealth64 (synchronize) = 25.8 fps
Mach64 (synchronize) = 25.9
Mach64 (transparent) = 26.2
Quake
Stealth64 (synchronize) = 17.7 fps
Mach64 (synchronize) = 17.7
Mach64 (transparent) = 17.8
Landmark v2
Stealth64 (synchronize) = 16,384 char/s
Mach64 (synchronize) = 11,045
Mach64 (transparent) = 12,288
Vspeed
Stealth64 (synchronize) = 19.91 million bytes/s
Mach64 (synchronize) = 17.33
Mach64 (transparent) = 19.54
Vidspeed (from mvspeed; 32-bit data transfer)
Stealth64 (synchronize) = 316.5 fps
Mach64 (synchronize) = 342.6
Mach64 (transparent) = 395.2
Windows 3.11
Wintune 2.0 (graphics)
Stealth64 (synchronize) = 14,144 Kpixels/s
Mach64 (transparent) = 8,406 Kpixels/s
Windows Speed (graphics)
Stealth64 (synchronize) = 999
Mach64 (transparent) = 698
Speedy (Hercules Computer Tech)
Stealth64 (synchronize) = 93.30
Mach64 (transparent) = 26.86
WinBench96 (custom selection of graphics winmark - because test 12 of 13 incompatible with Vision968)
Stealth64 (synchronize) = 13.52
Mach64 (transparent) = 6.91 (7.69 is the typical "graphics winmark" score)
From these results, the Mach64 and Vision968 seem fairly well matched, with benchmarks sometimes favouring one card over the other. Aside from DOS, the Vision968 has the benefit of running 1280x1024x24-bit due to the extra 2 MB of RAM. The Mach64 can do 1152x864x16-bit max. I will likely run the system at 1024x768x16-bit in Windows, so this difference is inconsequential.
1.08 MiB
976.37 KiB
1.25 MiB
Reply 2 of 50, by feipoa
I just added some Windows 3.11 benchmark scores, which indicate the S3 Vision968 is pulling way ahead of the ATI Mach64. On the flip-side, the Mach64 has a slightly better display quality. It would be interesting to compare these two high-end VLB graphics cards with an ET4000/w32p. Unfortunately, I do not have one.
Reply 3 of 50, by kixs
Both are great cards. Also quite rare these days and expensive. My first thought when I saw the title was, that S3 should be better in DOS, but Mach64 in Windows. But your tests show S3 being faster overall.
From my test (I also don't have w32p) even S3 864 VLB is faster overall then most of other high end cards (even Tseng w32i). I'm not sure how much faster if at all is w32p over w32i.
Reply 4 of 50, by Anonymous Coward
968 uses VRAM. For a proper comparison it should be benched against Mach64 with VRAM also.
Reply 5 of 50, by sliderider
And ATi just happened to make a Mach64 with 4mb VRAM, the Graphics Pro Turbo. I'm not sure if the Mach64 VLB with 4mb is VRAM or not. Mine is ISA and has VRAM.
Reply 6 of 50, by Anonymous Coward
Yes, VLB was also available as 4MB. The ISA version with 4MB is really pointless in my opinion. Anything above 1024x768x64 is too slow for ISA bus...even with acceleration.
Reply 8 of 50, by Anonymous Coward
Here are some of the results I got on my VL/EISA system. This is with an am5x86-160 in WT mode, SiS411/406 chipset with WB L2 cache, 64MB DRAM, 1024kb cache. Tests were done with a YMF-719 soundcard installed and enabled. Windows tests were done at 1024x768@64k in non interlaced mode.
Number 9 Motion FX 771 (S3 Vision968)
DOS
Doom = 1428 realtics
pcpbench = 11.2fps
pcpbench vga = 25.8fps
3dbench2 = 88.9
mvspeed = 314.9fps
Quake = 16.6fps
Landmark V2.00- 16948
vspeed = 18.43 million bytes/sec
WFWG311
Wintune 2.0 = 12.915kpixels/sec
Windows Speed = 999
Speedy = 55.79
Graphics Winmark = 13.0
ATi Graphics Ultra Pro Turbo VLB(Mach64 VRAM)
DOS
Doom = 1643 realties
pcpbench = 11.4fps
pcpbench vga = 26.0fps
3dbench2 = 80.7
mvspeed = 341.8fps
Quake = 16.6fps
Landmark V2.00= 11045
vspeed = 15.48 million bytes/sec
WFWG311
Wintune 2.0 = 11.077kpixels/sec
Windows Speed = 621
Speedy = 38.23
Graphics Winmark = 8.59
ATi Graphics Xpression VLB (Mach64 DRAM)
DOS
Doom = 1644 realties
pcpbench = 11.4fps
3dbench2 = 80.9
mvspeed = 342.8fps
Quake = 16.5fps
Landmark v2.00 = 11045
WFWG311
Wintune 2.0 = 8303kpexls/sec
windows speed = 579
speedy = 28.55
Graphics Winmark = 7.45
ATi Graphics Ultra Pro Turbo ISA (Mach64 VRAM) 8MHz
DOS
DOOM = 4326 realtics
pcpbench = 6.5fps
pcpbench vga = 18.2fps
3dbench2 = 36.0
mvspeed = 52.8fps
QUAKE = 13.2fps
vspeed = 3.32 million bytes/sec
landmark v2.00 = 2540
WFWG311
Wintune 2.0 = 6285kpixels/sec
Windows Speed = 196
Speedy = 11.46
Graphics Winmark = 3.84
Hercules Terminator 64 DRAM VLB(S3 Trio64)
DOS
DOOM - 1320 realtics
pcpbench - 11.8fps
pcpbench vga - 26.7fps
3dbench2 - 90.3
mvspeed - 476.2fpS
QUAKE - 16.9fps
vspeed - 20.64 million bytes/sec
landmark v2.00 - 20062
WFWG311
Wintune 2.0 - 10049pixels/sec
Windows Speed - 996
Speedy - 30.64
Graphics Winmark - 10.9
OCTEK VL VGA-1000 (Ark logic ARK1000VL) could not run 1024x768x64k in non-interaced mode
DOS
DOOM - 1306 realtics
pcpbench - 11.9fps
pcpbench vga - 26.6fps
3dbench2 - 90.3
mvspeed - 476.2 fps
QUAKE - 16.6fps
vspeed - 19.17 million bytes/sec
landmark v2.00 - 19660
WFWG311
Wintune 2.0 - NA
Windows Speed - NA
Speedy - NA
Graphics Winmark - NA
Hercules Dynamite Power VLB (ET4000W32P)
DOS
DOOM - 1363 realtics
pcpbench - 11.9fps
3dbench2 - 90.3
QUAKE - 16.6fps
mvspeed - 476.2fps
Landmark v2.00 - 19660
WFWG311
Wintune 2.0 - NA (Test could not finish)
Windows Speed - 957
Speedy - 62.31
Graphics Winmark - 7.99
Reply 9 of 50, by feipoa
Your Number 9 S3-968 performed worse than my test results in all cases, with the exception of a 3% increase in the Landmark score. The decrease in performance in your system is likely due to the L1 being stuck in WT mode as opposed to WB mode. This makes me wonder the benefits in using an EISA system for consumer use. I guess you can get faster ethernet transfers with the 32-bit EISA bus. To the best of my knowledge, there do not exist VLB ethernet cards. Also, I suppose you can use more than 64 MB of RAM, which it seems these VLB boards are limited to. I'm experimenting with another VLB board, one based on the UMC4980 chipset, and the manual mentions it is also limited to 64 MB of RAM.
Did your S3-968 card pass WinBen96 graphics? Mine would consistently not pass test 12 of 13, so I had to manually take the average of the 13 tests it did pass as my score, which was about 10% less than the score that WinBen provides had it passed. I am also using 3DBench, not 3DBench2.
The results of your Mach64 VRAM VLB vs. Mach64 DRAM VLB indicate no advantage in DOS when using the VRAM-based graphics card. The results are essentially equal. On the other hand, I noticed a consistent increase with all Windows-based benchmarks, more than I expected. However, those improved Windows scores do not even come close to the S3-968 results, so there is little incentive for me to hunt down a VRAM-based Mach64 VLB.
I would really like to see a Mach64 VRAM ISA vs. Mach64 DRAM ISA comparison though. Do you have these cards?
As expected, your Mach64 scores were generally less than mine, likely due to the L1:WT mode limitation of your chipset. I did, however, notice that your scores paralleled my "synchronize" scores. Is there a VLB "transparent" option in your BIOS? I noticed up to a 15% performance increase when using "transparent" over "synchronize".
Reply 10 of 50, by Nvm1
They actually do exist.. already had three in my hands 😀 All NE2000 based tho
Reply 11 of 50, by feipoa
Interesting. Do you have a photo? What are the sustained transfer speeds over the network compared to PCI 10/100 and ISA 10/100 cards?
Reply 12 of 50, by Nvm1
I don't have them anymore, they came from a company bankruptcy where lots of old systems had to be erased and destroyed some years ago.
Iirc they where from BOCA as brand and where called BOCALANcard? Or BOCALANVLCard or something like that.
Reply 15 of 50, by feipoa
Those BOCA cards are only 10Base-T, so I don't think they will have much benefit over an ISA 10/100 card.
dirkmirk wrote:
What speed does the PCI fsb run at when overclocked to 160mhz? I assumed that perhaps VLB would be faster than PCI when running a 40mhz fsb.
At either 40, 2/3*40, or 1/2*40 MHz.
Reply 16 of 50, by sliderider
That's why Mach64 with 4mb uses dithering to achieve 16.7 million colors. You still think you're seeing a true color image, but not all those colors are on screen at the same time, at least that's what it says on the box of my 4mb card.
Reply 17 of 50, by alexanrs
HighTreason has a video reviewing one of those, and indeed they perform horribly. If memory doesn't fail they performed worse than an ISA NIC he compared it to.
Reply 18 of 50, by Anonymous Coward
Seriously? Can you provide an image of the box?
Reply 19 of 50, by matze79
If you run Win95 the Mach64 will give you DirectDraw Support.
So a lot more Games will run on 9x. Pitfall, Jazz Jackrabbit II, Sonic..
