Reply 2500 of 27649, by Sedrosken
- Member
wrote:Mucking around with a P4 3.2 GHz machine. […]
I have an original Audigy (SB0090) in my P4 (2.8GHz Prescott, going up to a 3.2GHz Northwood here soon for working hyperthreading and better RAM I/O) and I can't seem to find the front panel breakout box for it anywhere. Found a few for the Audigy 2 ZS, but I don't *want* a 2 ZS, I want to use my existing Audigy. Honestly not sure why I want the breakout box, I never use front panel audio anyway.
But this P4 is still holding up for an interim main machine. Kind of surprising actually. I want to swap the 9600XT for a cheap used HD3650 AGP so I can use this thing for a couple modern games that I've seen run on this hardware, like Skyrim. It runs moderately well. I want to do it. And that card will give this machine the boost it needs to run Test Drive Unlimited adequately. I'd go for broke and grab an HD4670 instead but I'm gonna be honest, I don't see much of a point to it besides having the most powerful AGP card ever created, and breaking my bank trying to do it.
Anyway, enough random rambling, to get back to what the topic's about, today I played through Commander Keen 4 in DOSBox on this P4. Fun times. It actually played at full speed while this thing was running a defrag. On both drives at the same time. Even Doom stutters and stops in such conditions.
Nanto: H61H2-AM3, 4GB, GTS250 1GB, SB0730, 512GB SSD, XP USP4
Rithwic: EP-61BXM-A, Celeron 300A@450, 768MB, GF2MX400/V2, YMF744, 128GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428 VLB, CT2800, 16GB SD2IDE, 95CNOIE
