First post, by bakcom
I'm on a modern Nvidia card and Windows XP.
Anyone noticed uneven camera motion in Mafia (unrelated to frame rate)? If so, did you find a fix?
It's noticeable when the camera swings in larger motions, like when turning the car. You can see it even in the main menu when the camera moves as you select different options. It's not a showstopper but it does make the game feel choppy. Reducing graphic options didn't help, nor did disabling dynamic CPU clocking.
Another issue: aliasing. Turning on the x4 AA option helps some edges, but not all of them. There's also a lot of in-texture aliasing, like the guns on the table in the main menu. Various driver settings didn't help. Any thoughts?
