Reply 20 of 60, by PCBONEZ
wrote:I think power requirements sometimes over exaggerated. I had a PIII 1000 Coppermine rig that I recently took apart for another b […]
I think power requirements sometimes over exaggerated. I had a PIII 1000 Coppermine rig that I recently took apart for another built. It was my first attempt for a retro build, even long before I started involving with vogons, so it was some kind of a freak without no real practical purpose. The PSU of that machine was a an old and tired Aopen FSP300-60ATV with following specs:
+3.3V 28A
+5V 30A
+12V 15A
-12V 0.8A
-5V 15A
+5Vsb 2A
That is a Fortron Source (FSP) PSU OEMed to AOpen. Good solid period correct PSU. FSPs often need new caps after a while. It's hit and miss though.
The problem with using newer PSUs with older systems is by the time you get enough amps/watts on +5v for the older system the PSU has ridiculous amounts of +12v watts.
That makes the total watts higher than what it would be with an older spec PSU for the same amount of +5v amps/watts.
I will look at the other you wrote a little later. This time of day I'm only here 5 or 10 minutes at a time.
