DECAP runtime error
First post, by rygar
I'm trying to lunch old app DECAP (added as attachment) but without sucess. Maybe someone can help me?
Reply 1 of 8, by Davros
you need to be using a 32bit version of windows at the very least
a better bet may be running win 95 in a vm or native if you have suitable hardware
Reply 2 of 8, by rygar
I've created VM with windows 95 but it didn't help 🙁 I don't know what to do next...
Reply 3 of 8, by Davros
what happens ?
and what type of program is it
Reply 4 of 8, by rygar
It's old diveing decompression program. Here is article about it:
http://tunnel-lifesupport-usa.com/uploads/DCAP_Article.pdf
When i'm trying to lunch it it just didn't start. Ther're 2 executables:
decap2.exe -> didn't lunch
rt.exe -> gave me runtime error
I was trying to fix rt.exe bu using PATCHCRT.EXE and TPPATCH.EXE but without luck.
Reply 5 of 8, by Davros
According to that pdf it runs under xp apart from the print or printscreen function
try windows 7 xp mode or a xp pc if you have one
http://windows.microsoft.com/en-gb/windows7/i … de-in-windows-7
edit: its actually a dos program so use dosbox or dos on an old pc
fixcrt and tppatch wont do anything as its not written in pascal but fortran
ps: how come ive spent less than 2 minutes looking at the pdf file and I know more about the program than you ?
Reply 6 of 8, by rygar
I was trying Win XP but with the same resoult. Dosbox didn't work also. If you think it's easy to launch just tell me how. I attached whole app in my first post.
I really don't know why it's not working while it should...
Reply 7 of 8, by Davros
Crashes for me also (in xp)
maybe someone with a real dos machine can give it a go
ps: why not run a modern alternative ?
https://subsurface-divelog.org
Reply 8 of 8, by rygar
I want to launch it just for collecting purpose. I know there's a lot of modern alternatives:)
