First post, by Da Easy Mitch
I'm currently trying to set up a network game for Fatal Racing. So far all ist working flawlessly, as long as I add the server name to the .conf-file I use to start the client session. I start the client game using a .cmd-file with the following syntax:
<PATH-TO-DOSBOX>dosbox.exe - c "set SERVER=<SERVERNAME OR IP>" - conf <PATH-TO-CONF-FILE>
The problem is: The variable for SERVER only gets set after the autoexec in the conf file is processed, so it isn't set yet whe the autoexec calls "ipxnet connet %SERVER%" almost at the bginning.
Is there any way to add commands before the autoexec is run?
