voodoo and sli
First post, by cnpr
will a voodoo in sli work just fine with a Pentium mmx? I read the sli on that platform isn't very good so am i better off with just one voodoo 2 card?
Reply 1 of 23, by alexanrs
Voodoo2 SLI should work just fine, it would just be kind of a waste. An MMX processor can't really max out a single V2, let alone two, but it will let you play at 1024x768
Reply 2 of 23, by cnpr
ok will I need a 2d video card too? if so, what is a good choice of card.
Reply 3 of 23, by alexanrs
For an MMX? Any good 2D card will do. S3 Virge or Trio64 are popular due to great compatibility with DOS games, Matrox Millenium cards are popular due to great analog output quality and speed (but suffer from poor compatibility), and you can always try later stuff like some Riva TNT/TNT2, which would be a waste but who cares? xD
Reply 4 of 23, by brostenen
Why a faster system is needed instead of P1-MMX. If you want to have Voodoo on the system, I propose Voodoo1.
Save V2-Sli for a system like P-II-400, K6-2-500, as the minimum requirement's.
Yes. You need a 2D card. Get something like an S3 or Matrox Millenium for that, on a P1-MMX
Reply 5 of 23, by meljor
As had been said a voodoo1 is a great match on a mmx system, voodo1 is maxxed out with something like a p2-300 (more or less)
Voodoo2(sli) is perfect for a fast p3 system. However, since the v2 is a little bit easier on the cpu it will always be faster compared to the v1, nomatter what cpu is used. 1024x768 is a big plus for sli but i doubt your cpu can do much games at that resolution. Overclocking to 250mhz (3x83mhz fsb) will give you better performance out of the mmx. 3,5x 83mhz can be done on some cpu's stable.
This depends ofcourse on your board and which mmx cpu you use and what the multiplier is, or wether it is a locked or unlocked multiplier. 200mmx for example can do 250mhz no problem.
Reply 6 of 23, by cnpr
I would get a voodoo 1 but those things are around 75 dollars or highers. I saw a voodoo 2 around 55.
Reply 7 of 23, by cnpr
I would get a voodoo 1 but those things are around 75 dollars or highers. I just now saw one for roughly 22 dollars. it has 4mb or v ram it that good enough almost anything in the 90s.
Reply 8 of 23, by alexanrs
4mb is the standard amount for Voodoo1, and is the most compatible one of the bunch. A Voodoo1 won't be stellar for 98/99 games, for example, but neither will a Pentium MMX.
Reply 9 of 23, by Tetrium
Wouldn't this make the Voodoo 2 with 8MB RAM a lot more useful? A couple of mine came with only 8MB (edit: Just checked my list and all are 12MB except for 1. Thought I had more but this is ok too 😀 ), but if it can do basically anything what a Voodoo 1 can do, but faster, this would make a logical choice. However, I do remember there being a couple games that had troubles running on anything but a Voodoo 1 (perhaps it could partially be remedied by patches, but I don't remember).
Ehh...what? These used to be very cheap until recently though. Though Voodoo 3 AGP had always remained a bit cheaper as well
My retro rigs (old topic)
Report spammers here!
Reply 10 of 23, by alexanrs
/\ There are some statically linked DOS games that won't work with the Voodoo2 even with the environment variables.
Reply 11 of 23, by cnpr
what is statically linked for dos game? first I heard of it.
Reply 12 of 23, by gdjacobs
MW2 for one.
Reply 13 of 23, by Darkman
it will work but it will be a waste, I recently set up an V2 SLI config (12mb each) on a PPro200 machine and the difference between a single and SLI setup was under 5 frames in alot of cases.
Reply 15 of 23, by brostenen
If you know were to look, it can be found as low as 14/15 US Dollars.
Including cable and driver-cd. (shipping excluded in the price)
Reply 16 of 23, by cnpr
where? I am planning on buying one this evening. from there only thing i need is a 2d card for a decent price. thinking about leaning to a riva tnt 2 pci. I saw one for 10 dollars on ebay. I have rave pro turbo but I think the bios could be bad. I have a thread on that if any one can provide the bios for it.
Reply 17 of 23, by alexanrs
The TnT2 is a bit of a waste on such a machine, but should work.
Reply 18 of 23, by cnpr
actully I believe it a tnt m64 16mb pci
would any old vga cable do as long its Male to Female to connect 2d and 3d cards?
Reply 19 of 23, by Tetrium
firage wrote:
vetz has a compatibility matrix going on here: Voodoo 2 DOS Glide compatibility matrix
Only four such DOS titles left which won't work with V2.
Thanks for posting the link! I know there was a compatibility matrix but didn't know where it exactly was. Looks like I don't have any of the games that won't work on V2 so I shouldn't have too many problems. Still think I will be using V1 as I basically have no other use for them anyway 😜
