First post, by Guest
hi
i installed dos box today, i got the hint that "mad tv 1" will run with it. and it works. thank you.
i have a samsung syncmaster 172n TFT, resolution 1280x1024...
when i run dos box in full screen mode (i think it is...) i get a dos box window and a huge black area surrounding it... how can i get a REAL FULL FULL screen? 😉
my config:
fullscreen=true
fulldouble=false
fullfixed=true
fullresolution=1280x1024
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
