First post, by lontra
hi to all,
is there someone who can help me? how can i use an old game called Perestroika?
http://www.the-underdogs.org/game.php?id=2725
Thanks for any help
hi to all,
Thanks for any help
Do you mean that old russian game where you drove a frog? It had digitised pc speaker sounds (and voices) and used Borland's BGI libraries for graphics. Probably built using Turbo Pascal. I remember that it was a bitch to run outside real ms-dos, though. There is little chance that digitised internal speaker sound works in modern computer (timing issues?) Got one copy somewhere. I have to test it... Will post back... soon.
Yes, it is.
I have two software. The first was found in internet (perest.zip)(http://www.the-underdogs.org/game.php?id=2725), the second was the version in my old 386 (pere.zip).
Thank for your help.
Tested my copy. Built using Turbo C++ 3.0 - It works quite well under DOSBox except for the digitised sound. The other sounds are just awful. It runs like shit under a regular CMD.EXE window, btw (big timing issues because of digitised sound routines). So your best bet is to use DOSBox. 😎
Ok, i've just finised to test with DOSBox and VDMSound2 and it's ok. Only a question. Can i use bosbox in full screen? Thanks a lot for your help.
reading the documentation does mirracles (alt+enter)
Water flows down the stream
