Reply 10580 of 58246, by kithylin
That's not a computer. That's a furry animal living inside a metal box.
Reply 10581 of 58246, by Brickpad
Believe me, I found CHUNKS of dust that could qualify as intelligent lifeforms inside there.
Forgot to take pictures of the outside earlier. There is some slight yellowing of the case cover and bezel, but it's not very noticeable in the pictures.
Also, there is a huge downside to this computer - drive rails! It didn't come with drive rails for the 5.25" drive, so no CD-ROM is going in there for now. There is however a shop that is selling them online...for $86 a kit (5.25" and 3.5" pairs). 😠
Reply 10582 of 58246, by brostenen
Give it a bisquit or a cracker, then it will eat the whole arm. 😁
Reply 10583 of 58246, by stuvize
Interesting Vectra never seen that VL motherboard paired with that VE case only socket 3 boards I ever see in that case have SIS chipset and PCI slots. Nice find regardless horizontal Vectras with 486 CPUs are not very easy to source.
Cache module for Deskpro XE 560 arrived the other day never thought I would find one
Reply 10584 of 58246, by Timecop1983
Cambridge SoundWorks 4+1
Reply 10585 of 58246, by alexanrs
New 5V-heavy PSU!
ujZq7G9m.jpg?1
Was very dirty so I had to clean thoroughly... here are the innards:
fOxTm7Pm.jpg?1
Aaaand its full for "PCE-Tur" and "PCE-Tul" capacitors (appears to be from a brand called CEC from what I could find). Crap cap map:
WPaYrXrm.jpg?1
Its got two fans: an 80mm fan and a 90mm one.... the bigger one is fine, but the 80mm one is noisy as hell. Tried dropping some oil there but made little difference. Will need to get a new fan (and solder the connector) eventually... its not THAT bad when you use the knob on the back of the PSU to reduce the speed though.
Reply 10586 of 58246, by Skyscraper
I have not bought this today, it was a few weeks ago but I have not tested it until now. 😀
A fishbowl! I got rid of all VGA screens and sub 17" SVGA/XGA screens ages ago so I really needed one. The screen is a Packard Bell VGA screen with 0.39 mm dot pitch. 640*480 is the maximum resolution, it can do 720*400 EGA but not 720*480 so it wont work with DVDs in full resolution.
Packard Bell PB8539VG
The attachment Packard Bell PB8539VG VGA 0,39 Dot Pitch .JPG is no longer available
Reply 10587 of 58246, by rein_ein
Lots of stuff just arrived to my door,i'm so glad and gonna test it all right now!
Reply 10588 of 58246, by PCBONEZ
Yes CEC = CEC Coils. Owned by CEC International Holdings.
I think they stopped making caps to focus on their inductor and transformer business. No more caps datasheets online.
There were 9 varieties (series) of PCE-Txx that I know of. I have the datasheets archived if you need info.
Reply 10589 of 58246, by sirlemonhead
rein_ein wrote:
Lots of stuff just arrived to my door,i'm so glad and gonna test it all right now! […]
Nice! what's the Dell? looks a bit like a more modern revision of my Dell 333P's case
Reply 10590 of 58246, by rein_ein
Dell 425S/nP i486SX based powered up after swapping simm modules,looks like it missing original rails
and compaq deskpro 2000 or something like that keep showing me black screen and didnt start,working on it
Reply 10591 of 58246, by alexanrs
Are CEC capacitors bad? If they are I should probably replace them ASAP.
I'll accept your offer - I'd like their datasheets please. Thanks!
Reply 10592 of 58246, by sirlemonhead
rein_ein wrote:
http://i.imgur.com/PcnPwx7m.jpghttp://i.imgur.com/4ZSWioMm.jpg […]
Awesome! Same bios and all 😀
Any chance you could take some photos of the little metal shelf that screws onto the floppy drive that then screws into the case? I've lost mine and would like to look into replacing it.. Am thinking some sheet metal cut appropriately..
Reply 10593 of 58246, by Lukeno94
Wow, they really DID get some mileage out of that BIOS screen! I'm used to seeing that on Pentium 1-III laptops.
Reply 10594 of 58246, by HighTreason
Pretty certain my Grandad's Dell 286 had that BIOS too, or one very similar. That was an odd machine and I wish I had been able to get hold of it when he replaced it with a Mac, unfortunately, I was unsuccessful and I have no idea what happened to it.
Reply 10595 of 58246, by PCBONEZ
Unreliable. About like CapXon in PSUs.
I'm attaching the datasheets for the "PCE-Tur" and "PCE-Tul" you mentioned.
Those are probably the most common CEC seen in PSUs. If you need any others ask.
There is a lot of Chinese in them so some PDF readers might complain but if you can get them to load what matters is in English.
TUR are GP caps so upgrading to something like FC, PW, LXZ would be a good idea.
TUL are low ESR but their specs are splattered all over so it's best to look at the specific cap.
Reply 10596 of 58246, by alexanrs
Thanks! I'll look at them carefully tomorrow. I'll see what replacements I can source in Brazil, but I just might have to order them from the US through Digikey.
Reply 10597 of 58246, by PeterLI
Cool stuff everyone! 😀 There is still plenty of treasure out there! 😉
Reply 10598 of 58246, by Mr_ppp
Bought several bits and bobs recently, most notably a Promise Enhanced IDE controller the same as I had in my old 486, in very good condition boxed and two larger items which aren't specifically pc in the sense but worthy of adding to the collection!
The first is an Acorn Risc 700 in reasonably good shape, as a bonus it had a 5x86 card installed inside 😀 I've had to remove the leaking battery and treat the area as corrosion had set in but it still appears to work!
The attachment 20160206_023008.jpg is no longer available
The second is an Apple Powermac 4400/200, in good condition but dead as a dodo, from reading up I assume its the battery causing the issue
The attachment 20160206_023042.jpg is no longer available
These two cost me a grand sum of £7 😀
Reply 10599 of 58246, by Godlike
Like this mid 90s hardware and early 3D especially. A few builds can be resurrected from this components. Quake era makes me always smile
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
