Reply 120 of 382, by PCBONEZ
wrote:40w max is likely about right seeing they really don't put out much heat and the rest of the card is often stone cold, typical or average load is likely 25 or 30w.
No.
The Voodoo5 5500 has two 15w GPUs so it's essentially two 15+ watt video cards built onto one PCB. - 30+ watts.
The CPU is 5v powered and after VRM efficiency can pull up to 50 watts from the PSU at full CPU load.
3.3v+5v is already at 80+ watts - without considering the loads from the actual motherboard, RAM, drives or the other 5 add-in cards.
40 watts might cut it at idle, that's about it.
For their SE440BX2 board Intel gives the 3.3v+5v load at idle (at DOS prompt) using a low end video card (and no other cards) and 48Mb RAM as 24 watts.
That would be a very basic office computer at idle, hardly a gaming system.
It's not just the +5v that causes the problem.
3.3v+5v combined watts on modern PSUs is hard to find at 150 watts or more.
BX vintage correct PSUs often had 3.3v+5v combined watts limits in the 185w-230w range and there was a real reason for that.
The other reason you have to overkill the crap out of watts using modern PSUs is the get a high enough 3.3v+5v watts rating.
One with less than 150 watts (3.3v+5v) probably isn't going to cut it for a BX based gaming system with 6 add-in cards.
With the parts selection I would call this one a BX based EXTREME gaming system and even 150 watts (3.3v+5v) is iffy IMHO.
