First post, by NightSprinter
Is there anyone on this forum that's well-versed-enough with the MonArc Plus TSR programs out there? I have most games working fine, but there's so far a small handful I can't get to work at all. The games I have that won't work right are as follows:
Aldo's Adventure (screen too big for the resolution)
Aldo Again (same as Aldo's Adventure)
Any pinball game by DICE (scrambled graphics or image cutoff in hi-res mode, score display cut off or scrambled in low-res mode if Mode-X reprogramming is allowed)
Epic Pinball (menus are fine, but either no screen or scrambled display at 27KHz horizontal 55.6Hz vertical, which my monitor cannot handle the range between 16.25-30)
Jazz Jackrabbit (same as Epic Pinball)
Supercars International (same as the two games from Epic when those are in-game, as Supercars always runs at 640x480p60)
Turrican 2 (severe cutoff of the bottom third of the game screen, which would result in needless deaths and inability to see the status bar).
I'm just wracking my brain on this, as it's literally the ONLY utility that makes DOS games usable for livestreaming off of a real system. I sadly have no oscilliscope (or know how to use one) for measuring things.
