First post, by typh0id
- Newbie
Hey guys!
For the last couple of years I've been building a DOSBox drive that I can use like a virtual DOS machine. That is to say, I run DOSBox and then run all my games and apps from within the emulator as opposed to running each game with a separate shortcut from windows. So I've been trying to piece together the "perfect" .conf with the most universally accommodating settings that will allow me to run different games that have different needs without having to exit the emulator and change settings externally. Things like the "cycles" command are great but it doesn't seem as though "memsize" works from within DOSBox. I used to have it set at 16 until I ran into some games that needed 32 so I changed it to that and haven't had any trouble until now.
Syndicate Plus, seems to need it to be set at 16. So as I said above, this is likely a stupid question but is there anyway to get it to work with the memsize set at 32 or any way to change the memsize from withing DOSBox without exiting?
Thanks for humoring me!
