First post, by clueless1
- l33t
Just curious if you all keep a single 2GB partition or use multiple partitions on your DOS PCs. The reason behind the question is the optical drive letter issue with more than one HDD partition. I'm interested to know if you ignore this issue with the optical drive letter not being 'D:' or limit what you install to C:
Cheers!
