First post, by Sebastianxy1
How to get support 3dfx on dosbox svn ver (0.74.0.0) Windows on dosbox windows 95
MY CFG FILE http://cs414819.vk.me/u172562151/docs/25423fe … 4pbsdCxxy1&dl=1
Reply 2 of 7, by Sebastianxy1
collector wrote:
DOSBox questions should go in the DOSBox forum. This is for DOS games. Also, Win 95 is not supported in DOSBox.
im mount img file and boot p,s sorry im bad speak english
Reply 3 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Moved.
Neither Dosbox 0.74 nor SVN of Dosbox have support for 3dfx. Nothing you can do.
And it doesn't support Windows 9x (other than running IN it).
There are forks of Dosbox that support that but those are not supported here.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 7, by Sebastianxy1
Dominus wrote:
Moved. Neither Dosbox 0.74 nor SVN of Dosbox have support for 3dfx. Nothing you can do. And it doesn't support Windows 9x (other […]
Moved.
im downloading dosbox 0.74 ?
Reply 5 of 7, by Azarien
There are DOSBox forks (e.g. Daum) that have 3dfx support for DOS games, like Tomb Raider 1.
I have no idea if this 3dfx emulation would work under Windows 95 run under DOSBox.
What game are you trying to run and on what hardware?
Reply 7 of 7, by Azarien
collector wrote:
Daum is broken and not supported.
When will we see 3dfx support in mainline DOSBox, again?
