ATI VGA Wonder + issues
First post, by carlostex
Hello there fellow Vogoner's,
i recently got an ATI VGA Wonder +. These cards have decent image quality and a good level of CGA and CGA compatibility. My card also has a Bus mouse connector. I got the card boxed (no manuals or disks)and it came with a Bus mouse. I wanted to get the Bus mouse working on the XT.
These cards have a configuration program where you can store your configuartion on the cards EEPROM. Unfortunately when i tried to sav the configuration on the EEPROM it says: EEPROM failed... Very unfortunate as by default the Bus mouse port is disabled.
I tried the card on a different machine (my Socket 7 system) and the problem persists. So i took a look at the card. It's not my exact card but it looks exactly like this:
ati-1090009510-vga-wonder-video-card-6d9_zpsgzzzh4zw.jpg?t=1456409173
COuld it be the card has no EEPROM? At least none of the chips in there seem to be one...
Anyone around here has one of these cards?
Reply 1 of 10, by keropi
Under the empty crystall space on the pcb (upper left) there is a ram chip and on it's right an 8-pin device... What is it?
Also what is the large IC above the bios eproms? The pic is too small 😵
There is no other place/ic that I can see that could be an eeprom...
Reply 2 of 10, by carlostex
Allright after searching part numbers it seems that the HY 93C46 IC just under the empty crystal space is indeed a 1K (1024bit) EEPROM. So i'm wondering now if the EEPROM itself is dead. I'll try to get a plastic socket and a new EEPROM.
Reply 4 of 10, by carlostex
Good call, i'll try that as well.
Reply 5 of 10, by carlostex
Is it just me or there is something wrong in these pictures?
Trace marks but no actual copper !! And guess what no continuity whatsoever?
Reply 6 of 10, by elianda
I don't see what you mean, your pics look the same as on my cards and the setup program works.
Youtube Channel
Reply 7 of 10, by carlostex
Can you save the settings on the EEPROM?
Reply 9 of 10, by carlostex
keropi wrote:
it could be just a case of multi-layered pcb, maybe there is another layer inside that is not visible
That's what i thought too, maybe this is a 4 layer board or something, but still suggested traces show no continuity on the multimeter anyway.
Maybe the EEPROM is really dead. According to the datasheet these serial EEPROMS have High Reliability like 1 Million Write Cycles and data retention of 100 years. It could be a case of ESD damage however.
