Reply 3060 of 29774, by kithylin
- l33t
wrote:Lets play a game! […]
Lets play a game!
What CPU is this?
Bonus questen No1: At what speed is it running?
Bonus question No2: What motherboard did I use?Clues:
The L2 cache is activated in WB mode.
The L1 cache is of course active.
The motherboard has full support for the CPU.
All memory is cached.
All memory, cache and other BIOS settings are set to the fastest values.
The memory is 1x64MB 168pin SDRAM.
No slow down utilitys used and the system is not bugged or defect in any way.
Nothing is running in the background.
The PCI bus is running at its nornal speed, 33 MHz.
The only thing done is to set the CPU to the slowest combination of FSB and multiplier.
The OS is a clean install of Windows 98SE.The picture is only cut so I could fit the BMP on a normal floppy as I diddnt install jpeg support on the very speedy system.
You just need a different / older version of cpu-z to recognize it is all.
