Reply 10880 of 56798, by matze79
I used myself a EPIA 800 with a 3Dfx V2 Card as Mainsystem a long time.
My Computer was defective and i got one cheap.
As i could not effort a CPU, and a New Mainboard and a AGP Card this was pretty cheap for me.
It was running FreeBSD as Mainsystem and Windows XP for Games.
Played RTCW and Quake 3 on it, even Enemy Territory.
Reply 10881 of 56798, by rein_ein
Today i was god damn lucky (in my own kind),here the story:
Local pick up,finally got (as i thought) Supreme FX II X-Fi (Sound Max ADI AD2000B based) for 6$
I was so happy got it such cheap cuz i was looking for it for about 2 years coz my Asus Rampage Extreme (X48 based) came to me without it
So after coming home and removing cover i realized it was Supreme FX III X-Fi that is VIA VT2020 based
I'll give it a try with Asus maximus iii Formula(that it originally was from) sound drivers and guess what - it sounds like a charm,even try it with 5.1 all seems compatible well
Only thing not working now - led flashlights.
Reply 10882 of 56798, by kanecvr
xjas wrote:
While I was in there I spotted the cute Shuttle mini-PC case. It's pretty stripped; there's an Athlon XP / 962 board in there but nothing else, and especially no PSU (which is proprietary.) The form factor is apparently "flexATX" but Shuttle call it "Shuttle form factor" so who knows what fits it for mobos.
You can easily fit a micro-ITX motherboard in that shuttle case. As for the power supply, you can get a SFX psu in there with a little effort or modding. SFX is a bit shorter and wider then the shuttle psu, but you should be able to bolt it on there.
Reply 10883 of 56798, by xjas
Cool, that was what I was hoping when I grabbed it. If I can find something with a Core2 or Phenom-whatever and a PCIe slot for a video card in that size it would be perfect.
The other option is just to shove this setup that I already have in and make an ISA/DOS/Pentium-MMX machine that I can lug around:
[edit: photob*ck^t hotlink removed, because screw those guys]
...but that would take a fair bit of modding the back panel. Not out of the question.
Reply 10884 of 56798, by y2k se
It's a Shuttle proprietary XPC format. It will only take XPC motherboards and power supplies. There's also a specific CPU cooler they use. Your's looks like a SK41G. http://global.shuttle.com/main/productsDetail?productId=470
I've had three different XPC models. They are nice little computers.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2 SLI, SB Live!, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, AWE64 Gold, 40GB IDE HDD, Viewsonic A75f
Reply 10885 of 56798, by brostenen
I vote for modding time.... 😁
Reply 10886 of 56798, by kithylin
Found this today used at a thirft store for $30 out the door. Came with a nice shielded and filtered (both ends) attached VGA cable, even though I'm using the DVI port on it. VGA cable will go with my older computers.
http://www.newegg.com/Product/Product.aspx?It … N82E16824276050
Reply 10887 of 56798, by xjas
The attachment shuttle3.png is no longer available
...so that happened.
Turns out the original board is fine (the computer shop owner said it was dead.) It's running on an external PSU right now which isn't ideal (cables fed through openings with sharp metal edges), but it does work. And yes, *both* drives are supported in the bios:
The attachment shuttle5.png is no longer available
It's not going to win any speed awards, but it's kind of a neat board, with firewire, USB2, dual real COM ports (wow!), parallel port pinheader (there's even a punch-out on the back for one), dual FDD support, and optical SPDIF on the front panel. Sorry to disappoint anyone looking forward to modding time 😉 but I have use for it as-is for now.
The attachment shuttle4.png is no longer available
The attachment shuttle6.png is no longer available
Would be nice if I could put an Athlon 64 in there but doesn't look like it.
(And yes, I know I accidentally plugged into the wrong IDE channel. I already fixed it.)
Reply 10888 of 56798, by brassicGamer
Never seen that. Never seen a 5 1/4 inch drive in a shuttle case! 🤣
Reply 10889 of 56798, by Lukeno94
Good that you've got it to run! Definitely a no-go when it comes to fitting an Athlon64; they use completely different sockets.
Reply 10890 of 56798, by clueless1
Maybe that's the same one that the Newegg reviewer of that monitor had. 🤣
Reply 10891 of 56798, by Skyscraper
I just bought this video card for ~10 euro + ~3 euro shipping.
I already have more S3 PCI cards than I ever will need but I do not think I have any S3 968 cards, this seems to be the version with 220 MHz RAMDAC.
Diamond Stealth 64 Video VRAM PCI (S3 86C968-P)
The attachment Stealth64videovram.jpg is no longer available
Reply 10892 of 56798, by petro89
Received my voodoo 5 today! It has been just over 15 years since I've owned one of these. It's only fitting that I pair it with the same CPU I had it paired with back then (ok this is a 750 and that was a 700, but they are both Slot A Athlons).
*Ryzen 9 3900xt, 5700xt, Win10
*Ryzen 7 2700x, Gtx1080, Win10
*FX 9590, Vega64, Win10
*Phenom IIx6 1100T, R9 380, Win7
*QX9770, r9 270x, Win7
*FX60, hd5850, Win7
*XP2400+, ti4600, Win2k
*PPro 200 1mb, banshee, w98
*AMD 5x86, CL , DOS
Reply 10893 of 56798, by kithylin
Actually mine's completely flawless. All the ports work, displayport, dvi and vga.. no bad pixels, no bad blackness in the corners. I dunno what the heck those reviewers were smoking, but mine's perfect.
And cheap, $30 for a 1080p IPS LED Energy-Star screen.. yeah... 😎
Reply 10894 of 56798, by rein_ein
Nice catch,congrats.
Still looking for one of those tho.
Reply 10895 of 56798, by rein_ein
My catch today is DFI NT70-SC mobo,that came with 1gb(4x256mb) RIMMs
Originally i spotted and decide to buy just Rimms as upgrade for my 4x128mb,but after seller says: "ok lets me show ya how's it works" and showed me that board i'll ask him to buy it alltogether.
That neat bundle cost me 20$
Funny thing but seller asked 16$ for Rimms only
Reply 10896 of 56798, by Cyrix200+
Got two nice towers, one filled (but I did not have time to look inside yet):
Also some more CPU's:
1982 to 2001
Reply 10897 of 56798, by xjas
Nice, I have the stumpy version of that second case:
Yours looks like one of those '50s sci-fi "aliens" that was a human actor with a bald head extension. 😜
Reply 10898 of 56798, by bjt
^ Nice towers, those are beasts!
Finally picked up a SCP-55 for my 486 Thinkpad.
Reply 10899 of 56798, by Skyscraper
Thats is a really nice find, it cant have been cheap.
