First post, by uzernaem
Hello guys!
I would like to know if there is a way to emulate OpenGL 1.3 on Intel HD series GPU (OpenGL 4.1 compatible). I know the way to lower the OpenGL version for Nvidia GPUs (extension limit setting) but found nothing for Intels.
Thanks!
EDIT: What I look exactly is either a way to lower OpenGL version or OpenGL 1.3 to OpenGL 4.1 wrapper,
Reply 1 of 4, by leileilol
OpenGL is extension based and Intel HD surprisingly supports a lot of legacy 1.x extensions already, some not even supported by newer dedicated hardware
I don't think there would be much point in just dropping a list and version number for intel. I forget if that old 3DAnalyze! tool overrides GL version stuff, probably doesn't and might not work for 64-bit drivers
Reply 3 of 4, by Davros
If you cant find a tool that works renaming the game's exe to quake2.exe or mohaa.exe or CoDSP.exe or any exe of a game that had extension problems may help because the intel driver may have work around's for those games
Reply 4 of 4, by Azarien
And why exactly do you want to do that?
Saying "why" is sometimes more important than "what".
