Reply 10900 of 60008, by Lukeno94
Yeah, that kind of thing would be something I'd quite like, but I bet it would be well out of my budget.
Reply 10901 of 60008, by Cyrix200+
xjas wrote:
Nice, I have the stumpy version of that second case:
Yours looks like one of those '50s sci-fi "aliens" that was a human actor with a bald head extension. 😜
The stumpy one looks nice, but it is missing the MHz leds 😉 Mine is in bad shape though, plastic pins broken (dried out) so the back won't stay on and severely yellowed.
The other one is my favorite. It weighs a ton! It even came with the manual. Still no time to check the insides, I do think it has been fully upgraded once in the past...
1982 to 2001
Reply 10902 of 60008, by Api
Now I have monster sound. I've heard it makes other sounds too.
IntelSE440BX-2 256MB PII-300 Rage128 Voodoo2 SLI Vortex2 SB32 Win98SE
Asus A7N8X-E Deluxe 1GB Athlon XP2400+/XP3000+ Radeon 9600XT
FIC PT-2000 P120 Matrox Millennium 2MB Orchid Righteous 3d
Reply 10903 of 60008, by joc
This big, dirty, noisy mastodon is dual pentium II xeon @400MHz in very bad condition.
Siemens Celsius 2000
More then few things to fix...
The attachment IMG_20160303_221444.jpg is no longer available
Reply 10904 of 60008, by chinny22
Whats broken?
My Prolient 1600 was filthy when I got it last year (It had sitting in the corner of a carpeted office powered on for years) but nothing a good wash couldn't fix, and its only slot 1, you have the twice as cool slot 2!
Reply 10905 of 60008, by Lukeno94
Got a HDD caddy to use with my Satellite Pro 460CDX... one actually intended for use in the much newer Pro A200. But it fits, and it's allowed me to actually verify that the system does work, that it has a good keyboard and trackpoint (even though the rubber was gone), and is thus worth saving. Yey!
Reply 10906 of 60008, by joc
Whats broken?
PSU and mobo had few bad caps. I think that's fixed.
Mobo is still somehow unstable. Random restarts and lockups. Maybe my ECC module is incompatible? Gotta find another one.
Have no Hdd caddy and few more stuff is missing.
This machine was dumped in some warehouse for who knows how many years.
Reply 10907 of 60008, by Cyrix200+
It works!
Pentium 133MHz on a SiS mainboard, Sound Blaster 16 CT4180. Nothing really exciting 🙁 But the case is magnificent and the PSU works and that is all I wanted 😀
1982 to 2001
Reply 10908 of 60008, by Artex
That tower is an absolute beast!
Reply 10909 of 60008, by RacoonRider
That yellow "nose", is that an air intake hole? 😀
Reply 10910 of 60008, by brassicGamer
Wow - haven't checked in here for a couple of days. Some epic finds! Very much regretting giving away my Mobster Sounds 10 years ago 🙁
Reply 10911 of 60008, by Cyrix200+
Haha, no it's one of those sliding trays you can use to swap HDD's. This one is a bit wonky though, if you don't put it in just right the machine will fail to boot. I took it out, quite useless if you just have the one tray for it...
I plan on building my 'ultimate' AT system in it, not quite sure what to go for. I want it to be a bit higher spec than the case (which I guess had a 486 in it originally?). I'm contemplating a (S)S7 system or Pentium II or III. Put in a nice old CD ROM, 5.25"and 3.5"FDD, 2 HDD's. 😀
1982 to 2001
Reply 10912 of 60008, by PhilsComputerLab
That HDD bay device looks to be from a colani range of Vobis machines, the one that went with your tower looks different. I love that tower too. I remember a friend having this model. The power switch had this really chunky sound 😀
Reply 10913 of 60008, by Cyrix200+
Yup,good catch! The tower is a Vobis Highscreen. It even came with the manual with information on the HDD bay device. It does not really seem to fit though, more like the one in th desktop example in the manual. 😀
1982 to 2001
Reply 10915 of 60008, by PhilsComputerLab
Bought lots of AMD processors for socket 754 and 939. Some high end ones like the 4000+ with San Diego core, this CPU was what I wanted back in the day, but was too pricey. I never ended up getting it as I got a Core 2 Duo when it came out. Also some socket 754 motherboards with VIA chipset. Apparently the early nForce3 wasn't that great when Athlon 64 was launched and VIA was the better choice.
Reply 10916 of 60008, by Artex
Same here - ran an X2 4400+ Socket 939 & Nforce3 setup for years, until the "Code 43" compatibility issue surfaced between those dual core procs + AMD Video Cards + NF3 + Windows Vista.
Reply 10918 of 60008, by Scraphoarder
The attachment WP_20160305_09_16_41_Pro.jpg is no longer available
I also bought this Monster Sound. Second time i order from this russian eBay seller and are pleased with cheap prices and quick delivery.
Reply 10919 of 60008, by PhilsComputerLab
Great card, no doubt.
Scored a Radeon AGP X1950 Pro locally from Australia, that is always good as the shipping is reasonable. I'm having a ton of items incoming, will be a few trips to the post office over the n 😊 ext few weeks
