First post, by PoulpSquad
Walking down the path of bankruptcy, I got myself a new gadget.
I stumbled upon what appears to be an MT-32, old type (no headphone jack on the back) on eBay when there were only 2 minutes left!
After a quick search on Wikipedia, I came to the conclusion it was in fact the old type unit I was looking after and overbid my way to purchasing it.
Then I asked the seller for a shot of the serial number, (873017), and reading again the Wikipedia article, I realized there are
in fact *two* old types.
Revision 0 PCB, with serials up to 851399, and "new-old" revision, from 851400 to 950499, both without headphone jack in the back.
I was looking for an old type for Sierra games, so I'm wondering if I was too fast in buying this model, or if the "new-old" type is going to work ok
with old Sierra games.
Any help is as usual very welcome!
Some shots added for more details:
Reply 1 of 10, by Great Hierophant
Your MT-32 will work fine with any game, including Sierra's, intended to be played on an old-style MT-32.
Reply 2 of 10, by PoulpSquad
Thank you very much for the quick reply, I was getting nervous about spending money for nothing!
Reply 3 of 10, by Great Hierophant
Even if you did obtain the "wrong" module, it is much less common than the "right" module, so I'm sure you could sell or trade it for what you want.
Reply 4 of 10, by PoulpSquad
I guess, but I'm a sucker when it comes to this kind of stuff...
It's very hard for me to get rid of stuff like this, if I really had no use for it it would end up sealed in a cupboard.
But anyway, is there a specific game I could try to make sure? One that would sound odd from the start in an obvious fashion?
Also, if both an old MT-32 and a new MT-32 are hooked to the same BOB, it would be necessary to turn one or the other before launching a given game?
As I understand it, newer games on old MT can hang the computer, older games on new MT-32 might sound odd?
Reply 5 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
No, AFAIK the MT32 cannot hang a computer as the midi just gets put out but nothing is looped back. You can just "daisychain" the MT32s by connecting one to the computer and the other via the midi thru port of the first one.
You just need to replug the music output on your system or use a mixer to chose either MT32
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 10, by HighTreason
As you just want one or the other it wouldn't even be hard to make a box with a single DPDT switch to select as you could leave the ground wires connected together or absent entirely.
Expect some latency on the MT-32 furthest away, this is why nobody producing mused ever used the Thru sockets but it should be good enough for what you want to do.
Reply 7 of 10, by PoulpSquad
Learning something new everyday, thank you both for your help!
Reply 8 of 10, by gdjacobs
Wasn't HoC one of the games that took advantage of early MT-32 glitches?
Reply 9 of 10, by Great Hierophant
This should give you an audio reference to help you confirm what module you have :
https://www.youtube.com/watch?v=OLvsaJ4h-VY
Listen at 2:09:15 with Space Quest I VGA and if the "SpaceAlvin" sound is cutoff, then you have a new-style MT-32.
Reply 10 of 10, by PoulpSquad
Thanks a bunch! I'll make sure to check this out once I get the module.
