First post, by MrEWhite
Is there are any issues any has encountered while using DVI under DOS with a Geforce 4 Ti4600? It would be great to know as I am planning to use a DVI/VGA monitor for output with the Ti4600 and a Voodoo 2.
Reply 1 of 12, by PhilsComputerLab
Yes there are!
The DVI output on Nvidia cards give me a rather soft image. Other brands such as ATI or Matrox seem to have a better scaler.
The other issue is that it will output at 60 Hz instead of the standard 70. In some games this causes issues such as slower music, like in Lotus III. I believe that some DVI cards do output at 70 Hz, but I'm not 100% sure.
YouTube, Facebook, Website
Reply 2 of 12, by MrEWhite
Also, if I have a DVI and VGA cable plugged in at the same time, which would be the primary display in DOS?
Reply 3 of 12, by PhilsComputerLab
Every card behaves differently. FX series for example clone the image. So best to test all of this yourself with whatever parts you have.
Reply 4 of 12, by gdjacobs
I would expect it's video BIOS dependent.
Reply 5 of 12, by PhilsComputerLab
That makes a lot of sense.
Reply 6 of 12, by MrEWhite
I don't have the card on me yet, but I would expect the same result as a FX chip probably. Hope that the main one is VGA or cloned 😜
Reply 7 of 12, by nforce4max
Looks like you are building a nice win9x or xp rig but good luck with dos.
Reply 8 of 12, by matze79
i use a Radeon 7000 PCI with DVI, it has a very good Image, i also use a DVI2HDMI Adapter on it.
Works very well!
Reply 9 of 12, by Ace
I can't speak for the GeForce 4 Ti4600, but I've used the GeForce FX5600 and GeForce 6200 under DOS over DVI and the result was pretty good aside from some smoothing. What I particularly like about these cards, despite their smoothing, is the video displays in 1920x1080 on my TV, which, if you do a lot of video capture like I do, is a good thing since this resolution is accepted by pretty much any capture device (though most can only record at 30FPS).
However, I have not been able to get a single ATi card with DVI to display properly on my TV. I remember using a Radeon 7000 PCI like Matze79 did, but I honestly don't recall what the end result was, but on the Radeon 9000 and 9800 Pro I have, my TV rejects the video signal, a signal that appears to be upscaled to 1600x1200. My Samsung SyncMaster 244T may be able to accept the signal since it's a native 1920x1200 monitor, but my TV rejects it and so does my Elgato Game Capture HD60, so that's a no-go for me.
Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
Reply 10 of 12, by stuvize
The lack of VBE 3.0 may be why TVs don't like ATI or some other brands I ran into this trying to use TV as monitor Nvidia/3dfx are the only cards that would display properly, also in my experience Nvidia cards often have a poor quality image on DVI/HDMI seems to be a underlying issue at Nvidia this poor quality output is why MS claims they chose a ATI chip for the Xbox360 over Nvidia which was in the first Xbox. Although there do seem to be exceptions most LCDs look fine through HDMI if set to there native resolution when using a Nvidia chip but really soft looking at non native resolutions DLP TVs do not like Nvidia through DVI/HDMI at all looks much better through VGA or component
Reply 11 of 12, by swaaye
Ti 4600 should output fine but I'm not sure what to expect when you actually try game output modes through it.
Radeon prior to the X series had quite iffy DVI compliance. R200 and R100 chips especially.
Reply 12 of 12, by Trank
I sometimes use the DVI with a LCD monitor on my Ti4400. Never gave me an issue, maybe the picture wasn't the best, but it doesn't look bad at all. I never tried the DVI with a CRT though.
