First post, by xjas
I have this motherboard that I *think* is from a Dell Dimension XPS T550. I was re-homing it in another case but I don't know how to sort out this pwr/reset/etc. connector block:
The attachment DSC00272.JPG is no longer available
It looks like an earlier revision of the board had all the connectors individually spaced and labelled but then they combined them into the monoblock on the right and didn't bother to change the silkscreening. Has anyone dealt with one of these before?
The manual available from Dell says nothing about the connector beyond mentioning that it's there (calling it " Control panel connector (J8H1) "). Real helpful.
Here's the actual board BTW:
The attachment DSC00276.JPG is no longer available
The attachment DSC00277.JPG is no longer available
Reply 1 of 5, by Skyscraper
I use to poke around with a screwdriver in cases such as this. Hmm isnt the power on pins silk screened? It looks like they are.
Reply 2 of 5, by hyoenmadan
Well, for Dell you were not supposed to use that board with other case combination in the first place. They aren't motherboard vendors, but complete equipment vendors, so they aren't obligated to follow any connector standard that motherboard vendors would follow.
That aside, i guess they choose to fuse all the pins in a block because that block connects with a small board containing the switches, leds and sometimes even a Serial port header, in the ending side if i remember well. So it makes sense to use a flat ribbon cable and a connector header, than multiple twisted pair of cables and headers.
Reply 3 of 5, by bhtooefr
If there's solder pads for discrete connectors, that presents a multimeter opportunity - measure continuity between pins on the header connector and the solder pads.
But, yes, this would've been an attempt to reduce assembly time and costs, because they didn't have to worry about working in arbitrary cases.
Reply 4 of 5, by chinny22
If you can wait 1 day I had a site bookmarked with this!
Reply 5 of 5, by chinny22
This was the link I bookmarked years ago when I was thinking about using the motherboard in another case.
http://www.roberthancock.com/dell/fpconn.htm
Also check out the more information link on the 2nd line.
I never actually went though with the swap though so all I can say is good luck, its a nice motherboard apart from the pure evil non standard ATX connector.
