dgVoodoo 2 for DirectX 11
Reply 1660 of 3949, by Myloch
Hi dege,
have you ever thought about adding support for fancy 3d apis (like CIF, S3D, MSI, PowerSGL...)?
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 1661 of 3949, by teleguy
The Steam overlay is working fine now.
Reply 1662 of 3949, by VEG
Dege wrote:
Ok, I changed to 'unspecified' scaling mode when setting the desktop resolution, it still seems to work fine on my computers (AMD, nVidia).
If not even this one will work for you then I think I cannot do anything else for this issue. 🙁
Can we test it a little bit before release? 😀
Best regards, Evgeny
Reply 1663 of 3949, by VEG
Just a suggestion for the configuration utility. Check if dgvoodoo.conf is in the current directory and use it for editing if it exists in the current directory.
Reply 1664 of 3949, by Stiletto
Myloch wrote:
Hi dege,
Yes, I bugged him about it a while back. 😁
do the Fandango!" - Queen
Stiletto
Reply 1665 of 3949, by Dege
Yes, I just made some other changes so partly re-testing DX/DX8 was needed.
I intend this state to be the final one altough I found regression bug(s) in Glide that are still to be fixed (Diablo II, dynamic shader compiling).
I also fixed some gamma-ramp related problems in DX8, so Need For Speed Hot Pursuit 2 and NFS3 with DX8 renderer both work now.
http://dege.fw.hu/temp/dgVoodooWIP19.zip
Stiletto wrote:
Myloch wrote: Hi dege, have you ever thought about adding support for fancy 3d apis (like CIF, S3D, MSI, PowerSGL...)? […]
Myloch wrote:
Hi dege,
Would be nice, but I'm not planning it now, it all is too time-consuming.
Reply 1666 of 3949, by VEG
Dege, thanks. This one works good 😀
But what about this suggestion?
I would like to place dgVoodooSetup.exe in the drivers/dgvoodoo/ subdirectory, and it will be nice if it detect dgvoodoo.conf in the own directory and start to edit it automatically.
Another suggestion to change the name of dgVoodooSetup.exe to dgVoodooConf.exe. Just because Windows thinks that dgVoodooSetup.exe have to setup something, but it doesn't, and as the result Windows sometimes asks me if this installer is failed. Just stupid heuristics =)
Reply 1667 of 3949, by VEG
Does dgVoodoo Napalm support these sizes of the textures?
/* Napalm extensions to GrLOD_t */
#define GR_LOD_LOG2_2048 0xb
#define GR_LOD_LOG2_1024 0xa
#define GR_LOD_LOG2_512 0x9
UPD. I have tested it and it seems that it supports these texture sizes 😀
Reply 1668 of 3949, by lowenz
Texture corruption problem with stretching+AR is camera angle dependent:
Reply 1669 of 3949, by Dege
Cool!
VEG wrote:
But what about this suggestion? […]
Ok, I can do that. If the current folder is already in the folder list then it could be selected by default, instead of the user appdata folder.
Right, I think dgVoodooSetup is not the best name, after all it's a configurator, but it's a legacy from dgVoodoo1. It's a pity I choosed that back then (what is more, it would have been better not to name this wrapper 'dgVoodoo').
But I won't rename it in this version, I should re-draw its icon. 😁
VEG wrote:
Does dgVoodoo Napalm support these sizes of the textures? […]
Yes, but only if a Voodoo4 is selected as the virtual card ("Other greater").
lowenz wrote:
Texture corruption problem with stretching+AR is camera angle dependent: […]
I wish I could reproduce it myself.
Reply 1670 of 3949, by lowenz
If you have Republic Commando, try to change the resolution in-game (with dgVoodoo obviously 😁 ) and look around.
Reply 1671 of 3949, by Matsilagi
Dege wrote:
Yes, I just made some other changes so partly re-testing DX/DX8 was needed. I intend this state to be the final one altough I fo […]
Myloch wrote:
Hi dege,
This WIP made Megarace 3 stop working.
Just bug reporting, it tries to start then crashes
Reply 1672 of 3949, by VEG
I've added an ability to use large textures 512×512, 1024×1024 and 2048×2048 in the NFS3 Modern Patch. It would be nice to have an ability to choose more Onboard RAM, e.g. 32MiB, 64MiB, or even 128MiB.
Reply 1673 of 3949, by daniel_u
I think you can type in the amount of RAM for the card you're using. Nice addtions to the rear view window.
Maybe after you finish with NFS 3 you can start with Splinter cell/ Pandorra T. 🤣 I'll send you some beer if this will be happening. 😀
@Dege. Fast access works for Splinter Cell PT. The light color problem is still there. For texture corruption try changing the resoltion to 640x480.
At this resolution there were some problems if i remember well, while certain mouse movements were performed(including black textures in certain areas).
There are also a number of game issue(non dgvoodoo related) dependent on mouse movement in SC PT. It would not be a bad ideea to see whats happening. 😁
Reply 1674 of 3949, by Dege
I couldn't reproduce the texture corruption myself, but, found a very basic bug around the scaling that, according to the symptoms, can smoothly cause it. 😊
Does this fix solve the problem for you?
http://dege.fw.hu/temp/dgVoodooWIP19_1.zip
Trying to run with 'Unspecified' scaling mode? That's the one it works with (and ATI 8500 preset).
Otherwise it crashes at once for me too.
Reply 1675 of 3949, by lowenz
Not Found
The requested URL /dgVoodooWIP19_1.zip was not found on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Reply 1676 of 3949, by lowenz
Maybe there is no "temp" subdir in the URL :p
Reply 1677 of 3949, by lowenz
Addendum: why the size of D3D8 has grown so much? (130->600 KB)
Reply 1678 of 3949, by lowenz
YOU GOT IT, MAN! Problem solved (in Splinter Cell Versus).
Reply 1679 of 3949, by VEG
I think that Dege just forgot to pack this dll file. Usually he use dll/exe packer, but it is not a good thing. Packed DLL extracts itself every time when it is used.
