First post, by 386SX
I would like to test this old AGP card (2003 build date) that seems to not be installable with usual Rage 128 drivers. I tried all the one I found but I had to force the latest default ones but they seems to be unstable with it. Anyone have seen some original latest drivers? I don't remember there were differents revisions, but it seems to have a different chipset from the other R128Pro I've seen. I didn't even remember there was an Ultra version...
Thank
Reply 1 of 3, by Putas
My Ultras certainly work with Rage 128 Pro drivers.
Reply 2 of 3, by havli
Rage 128 Ultra has different device ID... and because of that regular driver doesn't detect it. It should work just fine when you install driver manually via device manager. Just browse the *.inf file and then choose this crazy name 🤣 http://abload.de/img/r128u2_128_32_3dm01_1duu9j.png
Reply 3 of 3, by 386SX
thanks! I will try that model name to see if it works. It is interesting that they were still built in late 2003 much later of the usual rage128 life.
