This morning, while I was cycling to work, I found in front of a house an entire PC, along with two CRT 15" monitors, all in good condition, after all. Once brought everything home with my car, in the afternoon, I could have a closer look at the 'loot':
opened up the case, apparently in good condition and free from bruises, I could see right away that, with my surprise, it was a motherboard with dual socket PGA370, the Tyan Tiger 230T. Mounted on this one I've found a single Pentium III Coppermine @1GHz, 2x128mb PC133 SDRAM, VGA ATI Rage Pro, a x3 firewire card, a SoundBlaster PCIx model I think, and with my interest/curiosity, a card for receiving Sat TV directly on your PC, model 'Sky2PC '. Besides these pieces there were floppy drive (disconnected), 2x optical drives and 2x Samsung 40gb 7200rpm hard drives, identical models. Being SDR fan, I would be curious if you can use the Sat TV card for radio reception of some kind, a bit like what I do from time with USB sticks initially engaged for the same purpose of DVB and then modified for VHF radio reception.
