First post, by Anony
Picture this:
Image mount a floppy, start installing a program off the floppy, when the install program asks for disk #2.. well I'm screwed because it was an image, not an actual floppy that I can switch out.
Since Dosbox is well.. DOS, I can't get back to the terminal once I'm in a program (see: Control-Z) to unmount image Disk 1 and mount image Disk 2.
How difficult would it be to add some sort of way to mount drives behind the scenes, either in the 2nd status window, or by a (windows) drop down menu?
(Or is it supported already?)
