First post, by Half-Saint
- Oldbie
I picked up this massive tower at the dump yesterday morning, not really knowing what it was. The case badge is from one of the first slovenian resellers called Mlakar (later renamed to Mlacom). Inside I found a 486 VLB motherboard with a 486DX2-66 installed, 8MB of RAM and 256k of cache. There are also two unidentified 3.5" hard drives inside, one of which (C:) refuses to be detected in BIOS and won't boot. Both hard drives are extremely noisy, even louder than a Thermaltake Volcano 7 at full RPM. It came without a sound card and the video card is some weird 1MB Realtek ISA card.
The machine itself works although the battery has started to leak so will need to be replaced ASAP. It's also surprisingly clean inside and outside - there was only a little bit of dust in the power supply.
Here's a photo with the mini socket 370 PC I mentioned in another topic for comparison:
The motherboard, anyone know maker/model?
