clueless1 wrote:I envision having a number of "reference" benchmarks scattered throughout. So maybe I could take the average 386/40 from Phil's […]
I envision having a number of "reference" benchmarks scattered throughout. So maybe I could take the average 386/40 from Phil's chart and place that into this chart so someone knows what a typical 386/40 scores in specific benchmarks. And the average 486/25, etc.
Something like this. The red values are median results taken from Phil's chart.
Well, i had nearly the same idea a few months ago. I was already buying & building up my Super-socket system, little inspired from Phil's video 'time-maschine', and i also want to know, what is possible with my K6-2(CXT) even in comparison with the properties Phil has used.
To compare my underclocked K6-2 with the three modes (L1+L2 On, L1 Off and L1+L2 Off), i've extracted the most reasonable data from Phil's VGA chart for the following CPU's and average them. For fast comparisons, I've compared only the two benches 3DBench2 & PCPBench:
386DX-25, 386DX-40, 486DX-25, 486DX-33, 486DX2-66, 486DX4-100, Pentium 60
I've also compared the values of Phil's test values, when he was running the WingCommander Comparison with 386DX-25/-33/-40 and corresponding 3DBench2 & PCPBench values.
Additionally, i've also added Phil's test values from his video 'time-maschine' and the underclocked K6-III+ with 133MHz for the '386-mode' and '486-mode'.
(The values for 386DX-16 and 386DX-20 are interpolated from the average value of DX-25 and have to be seen carefully.)
Finally, i've compared these values with my benchmark results, and i've made additionally the WC-test. All tests i've made at the lowests clockspeed. Additional tests with higher clockspeeds were only with full enabled caches.
I know this is maybe not exactly accurate for statistics, but it gives a approximate number for example which speed is necessary to play WC.. 😎
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
