7-zip benchmarks for over 60 CPUs
Reply 20 of 209, by agent_x007
Kudos for OC (4,8GHz is awesome with Haswell)... but still not enough to beat my new score 😉
The attachment 7-zip i7 5,13ghz.png is no longer available
Want to try again ?
PS. I'm no expert in Haswell... but isn't 1,4V+ kinda much for 22nm Intel transistors ?
(I heard they tend to run quite hot after 1,35V).
Reply 21 of 209, by Tertz
As the results may depend on 7zip version, so you need to write it near the results.
Besides multi-thread, single-thread bench would be good to place here too.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 22 of 209, by rodarkone
@ tertz All the tests are done on 9.20 (as requested by clueless1) not sure about the single/multi thread (where this can be setup)
@ agent_x007 - your cpu is mad 😀 - mine dosn't want to go at 5 GHz no matter what vcore I am pushing (and yes 1.4 is too much /definitely not for 24/7 .. if I run it at 4.6 runnes fine with Vcore 1.285-1.289 V:) - but if I am pushing more after that he wants more anyway - good score and good cpu a true beast 😀
Reply 23 of 209, by agent_x007
That's why I didn't bought Ivy/Haswell/Broadwell so far.
They just can't make the frequencies that legendary Sandy Bridge can 😀
True - they are all faster clock vs. clock than it, BUT they just can't scale with frequency that well.
Performance = IPC x Frequency, and to me Sandy Bridge is (for now) the best IPC x Frequency combo (Skylake/Kabylake may be better, but first intel has to get the hang of making 14nm transistors).
Also, Quad Channel can help out in this test 😉
PS. All my scores are from 9.20 64-bit edition and done on Air cooling 😜
Reply 24 of 209, by havli
Need moar cores 😈
Using 7-zip 9.20 x64
Reply 25 of 209, by swaaye
Opteron 165
MSI K8N Neo 2 (nForce3 Ultra)
2x1GB PC3200 2.5-3-3-6 CR1
XP 32bit
7z 9.20
Reply 26 of 209, by clueless1
Thanks, swaaye. Added to the sheet. Nestled in quite nicely between the C2D E6300 and Pentium D 945.
Reply 27 of 209, by sprcorreia
Added two results: i5 4460 (stock)(windows 7) and Athlon 64 3200+ (stock 2.2GHz, Venice core, s754)(windows 98).
Reply 28 of 209, by swaaye
Added results from my Kangaroo PC. Atom X5 Z8500. It runs 10x64 but I again used 32-bit 7z 9.20.
Reply 29 of 209, by tyuper
The attachment 7zip.png is no longer available
Reply 30 of 209, by clueless1
Nice result on the overclocked Q6600, tyuper.
Can anyone beat the P3-933 for lowest score? 😉
Reply 31 of 209, by rodarkone
The only one that I have as of now 😀
Reply 32 of 209, by clueless1
What's a Celeron III? 😀 The cache size makes me guess it's an underclocked Tualatin Celeron? I put it in the database, but you can go in and correct the description if you like.
Reply 33 of 209, by rodarkone
Sandra error - is a P3 Copermine 600E / SL43E
Reply 34 of 209, by kithylin
Donating my two systems to your database. Maybe a 3rd in a bit.. could do my file server but it has so much crap running that it'd be inaccurate. Might just try it anyway.
Anyway, system #1, then I'll post again for my newer system in a bit.
If you could please sort these into your list for me that would be nice. I'm half sick and don't have the brain power to do it right.
EDIT: Second system.
I have a 4-way Pentium-III Xeon Server I can try to run this on later tonight after food. About to go eat now.
I don't even remember if I have hard drives / OS in it or not. I'll see about powering it on and see what it can do in a little while. That might be an interesting thing to add to your database. Quad-Core Pentium-III 😁
Reply 36 of 209, by kithylin
clueless1 wrote:
Thank you, sir. Results added. Yeah, a quad core P3 would be sweet. 😀
I have it and it's running but no OS on it at the moment. Not sure if I want to bother going through that tonight, I'll think on it.. not feeling well. Maybe later next month.
Reply 37 of 209, by havli
Here is the result of 8-core Sandy Bridge-EP Xeon. Not fast enough for the first place, but still respectable performance. 😀
Reply 39 of 209, by Spaz
Here is the result of my Haswell-E 5960x CPU at stock speeds (3.5Ghz turbo) 😀
