Windows 98 DirectX 9
First post, by MrEWhite
I saw that on Vogons, many people don't recommend installing DirectX 9 on Windows 98. Why is that exactly?
Reply 1 of 30, by mrau
afaik it's not supported, depends on how old the installer is that you use
Reply 2 of 30, by MrEWhite
Talking about the last official version.
Reply 4 of 30, by Imperious
Personally I think that's rubbish, I've installed dx9c on all my Win98se machines and haven't encountered any problems.
I guess if You are only wanting to run older titles and have an older machine, and have a video card that is dx8.1 hardware or older
then maybe installing dx9 might reduce performance. I would have thought someone must have benchmarked this by now?
Reply 5 of 30, by swaaye
I typically run DirectX 7.0a because after lots of experimentation over the years I've found this version to be the last really stable choice. Anything beyond that and I see more frequent BSODs, especially with subsequent launches of 3D programs during a single session.
Reply 6 of 30, by PhilsComputerLab
I also use 7.
Question: Are there even any DX8 games, that do not run under Windows XP?
Reply 8 of 30, by clueless1
PhilsComputerLab wrote:
I also use 7.
The only one I'm aware of is from an unofficial patch: Unreal.
On my Win98 PC I have a DX9 card (FX5200) and with the oldunreal.com patch I can run Unreal in D3D9 with better performance than any other D3D or OpenGL mode in the game.
Reply 9 of 30, by PhilsComputerLab
I also use 7.
Nice, that way you get A3D sound as well as good looking graphics...
Reply 10 of 30, by Arctic
I never had any trouble using DirectX 9 on Windows 98SE. I use 8.1 mostly.
But if you fancy 9, go for it 😀
Reply 11 of 30, by hyoenmadan
This sounds more a bad/bugged driver problem than a DirectX library problem. Also, never mix newer Video drivers with VxD legacy drivers like Audio and Joystick. This surely will end in frequent BSoDS. DirectX9 was designed to work in a WDM environment, so supply it with correct WDM Audio/Video/Joystick drivers.
If you need legacy drivers, you will be better served by DirectX 7/8.
In effect, this is the only way to get the best performance and no stuttering from ATi/AMD Radeon cards, at least with this game (and yeah, i still play it 😉).
Reply 12 of 30, by swaaye
I think you could be right. The problem is that the WDM 9x drivers for sound cards usually do not produce correct 3D audio. Some cards don't even have WDM options.
D3D8 doesn't work better than 9 though. You specifically need to stay on DX7.0a or below.
Reply 13 of 30, by maximus
I asked a similar question a while back and got a similar mix of responses:
DirectX compatibility problems: fact or fiction?
I always use DirectX 9.0c (Dec. 2006) and have never had any issues. (None that I could trace to DirectX, anyway.)
Graphics and sound drivers seem to be the critical pieces as far as compatibility and stability are concerned.
PCGames9505
Reply 14 of 30, by bjt
I also use 9.0c on my Athlon Win98 machine, it was necessary for Tron 2.0. No problems here.
Reply 15 of 30, by swaaye
Video and sound card details? Driver versions are useful too. What games and programs have you spent a significant amount of time running?
Reply 16 of 30, by RoyBatty
I'd stick to directx9.0b myself, before they started messing with directdraw.
Reply 17 of 30, by swaaye
Seeing about 5 threads about this in the past year or so has me experimenting again.
Thus far I've found one example of DirectX 8-9 being a problem in 98SE. If you run a Vortex 2 card and play Wheel of Time, WoT.exe will completely lock the PC the second time you try to run the game. If I uninstall the Vortex 2 driver (2041) or revert to DirectX 7.0A, this no longer occurs. I tried DirectX 8.0, 8.1, 9.0b and 9.0c and each exhibits this issue.
Lots of games seem to work fine. I recall this being a problem with Sin and Homeworld but I haven't gotten to those games yet. Homeworld Cataclysm works ok though.
So be wary of your old sound card drivers if you must run > DirectX 7.0a.
Reply 18 of 30, by notsofossil
DirectX 9.0c is required for later made ATi Catalyst drivers.
I've never had a problem with the unofficial DirectX 9.0c installer, I don't remember where I got it from.
Thinkpad T42 Win9x Drivers | Latitude D600 Win9x Drivers
Next: Dell Inspiron 8000
Reply 19 of 30, by swaaye
It's not. I know the ATI installer warns you about it but you can definitely run say Catalyst 6.2 with DirectX 7. I was doing this just a few days ago.
