First post, by legluondunet
Hello,
I would like to play old game like Motoracer 1 et 2.
I installed Windows 98 on Virtualbox but it doesn't support hardware acceleration, so this directx games don't launch.
I know that Dosbox could support WIndows 9x with hardware acceleration? Is it true?
How to compile it (I'm on Linux Ubuntu) and install WIndows 98?
Thanks for the help.
Reply 2 of 10, by Xelasarg
Check out this guide.
If you need 3dfx emulation, use ykhwong's build. It's highly experimental, so expect it to be a bit buggy here and there. But overall, it runs Win9x quite nicely.
"What's a paladin?!"
Reply 3 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
No, don't use ykhwong's build. It is very buggy and based on Dosbox-x which has seen a lot of development since ykhwong flawed build
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 10, by Sammy
Use Dosbox Daum fron 27 Jan 2014 with Win98, (but more stable with win95).
But it's better to search for the motorracer patch for win xp / 7 and run it under xp /7.
u can also run patched Motoracer on a virtual xp with 3D hardware accelleration in virtualbox, vm player, or something.
Reply 5 of 10, by Tertz
ykhwong's build has Voodoo 1 emulation (DX5 games) wich works ok only in software mode what is slow in many games as there was not implemented a separate CPU thread for 3D card emulation. It's better to look for other variants for 3D games.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 6 of 10, by Azarien
What alternative do you propose for 3dfx?
Reply 8 of 10, by kjliew
Check out Tutorial: dosbox with Glide under Linux for building DOSBox w/ 3Dfx emulation for Linux.
Patch for kekko 3Dfx voodoo emulation on DOSBox SVN is available in the same thread.
Reply 9 of 10, by Azarien
Tertz wrote:
try glide wrappers
The only setup that I managed to get working on my semi-retro laptop is Dosbox Daum + dgVoodoo 1.
Reply 10 of 10, by leileilol
What about dgVoodoo 2 then? That also has a Direct3D wrapper.
Debian's fucked
