Long File Name (LFN) support (SDL1)
Here you can discuss the development of patches.
Re: Long File Name (LFN) support
Postby Wengier » 2016-4-07 @ 21:24
avx wrote:This build has issues with atleast System Shock 1. With last years build it did not start, with the 20160327 build it now starts but cannot find the sound config. (I have it set to general midi + GUS)
Thanks for reporting the issue with System Shock 1! I have fixed the problem finding the sound config as you described (I have tested Sound Blaster and General MIDI, both worked now) in the 20160407 build. This 20160407 build also incorporated the changes from the latest DOSBox SVN r3979, and download links for the Windows binaries remain the same as previous versions. If you find any other issue please report it too. Thanks for your support.
Wengier
Postby Wengier » 2016-4-20 @ 16:52
I have updated the DOSBox SVN-lfn source and Windows binary to build 2016.09.26, which fixes some issue and also incorporates the changes from the latest DOSBox SVN version r3995. It now further contains LPTx port passthrough feature for printing support (see README.TXT inside the binary packages for more details). The download links for the Windows binary remains the same (i.e. http://bit.ly/12jANWF for the Visual Studio build and http://bit.ly/1laDvGX for the MinGW build), and the latest diff and source files changed from the latest DOSBox SVN version have been uploaded in the attachments (EDIT: please download the latest diff and source files from my next post).
Wengier
Postby Wengier » 2016-9-11 @ 19:55
Updated for DOSBox SVN 4006. Also added the APM power down feature to shut down DOSBox SVN-lfn and (for Windows) DOS APIs that communicate with the Windows clipboard directly (e.g. 4DOS's clipboard feature via the CLIP: device name will work). The source code changes have been attached.
You do not have the required permissions to view the files attached to this post.
Wengier
Postby roytam1 » 2017-9-05 @ 13:48
Wengier wrote:Updated for DOSBox SVN 4006. Also added the APM power down feature to shut down DOSBox SVN-lfn and (for Windows) DOS APIs that communicate with the Windows clipboard directly (e.g. 4DOS's clipboard feature via the CLIP: device name will work). The source code changes have been attached.
This(170905) build seems has bug when I start RICH3 with super slow motion. (20161007 build is fine)
EDIT: Oops. This is actually an old bug happens after r4000. A bug report is filed. https://sourceforge.net/p/dosbox/bugs/467/
roytam1
Postby Wengier » 2017-9-17 @ 02:50
I have updated the DOSBox SVN-lfn to match the latest DOSBox SVN version 4052 in the latest build, which should include the fix linked from the above post, and also new commands FOR and PROMPT are added to the build. The download links for the latest builds remain the same.
Wengier
Previous
Return to DOSBox Patches
Who is online
Users browsing this forum: laxdragon, PoulpSquad and 1 guest
