First post, by Elia1995
Hello, recently I'm having this weird issue on DOSBox, being quite laggy on some actually light weight games.
The games where it's a lot noticeable are: Blupimania (it's extremely choppy, even with maximum cycles and CPU) and a lot of 2.5D games, such as Blake Stone and Rise of the Triad (ROTT), Duke Nukem 3D runs a bit less laggy (and I play it with EDuke32 due to that issue... I'd love to play it again how it was supposed to be played though...), Doom, on the other hand, looks quite smooth.
Most games I play look flawless on DOSBox, but some are unexplainable laggy and unplayable, first of all Blupimania, which was one of my favourite puzzle games of my childhood and I'd really love to play it again... 😢
Here's my DOSBox config file
# This is the configuration file for DOSBox SVN-Daum. (Please use the latest version of DOSBox)
# Lines starting with a # are comment lines and are ignored by DOSBox.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen. (Press ALT-Enter to go back)
# fulldouble: Use double buffering in fullscreen. It can reduce screen flickering, but it can also result in a slow DOSBox.
# fullresolution: What resolution to use for fullscreen: original, desktop or a fixed size (e.g. 1024x768).
# Using your monitor's native resolution with aspect=true might give the best results.
# If you end up with small window on a large screen, try an output different from surface.
# windowresolution: Scale the window to this size IF the output device supports hardware scaling.
# (output=surface does not!)
# output: What video system to use for output.
# Possible values: surface, overlay, opengl, openglnb, openglhq, ddraw, direct3d.
# autolock: Mouse will automatically lock, if you click on the screen. (Press CTRL-F10 to unlock)
# sensitivity: Mouse sensitivity.
# waitonerror: Wait before closing the console if dosbox has an error.
# priority: Priority levels for dosbox. Second entry behind the comma is for when dosbox is not focused/minimized.
# pause is only valid for the second entry.
# Possible values: lowest, lower, normal, higher, highest, pause.
# mapperfile: File used to load/save the key/event mappings from. Resetmapper only works with the default value.
# pixelshader: Pixelshader program (effect file must be in Shaders subdirectory). If 'forced' is appended,
# then the shader will be used even if the result might not be desired.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
# overscan: Width of overscan border (0 to 10). (works only if output=surface)
fullscreen=false
fulldouble=false
fullresolution=desktop
windowresolution=original
output=direct3d
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-SVN-Daum.map
pixelshader=none
usescancodes=false
overscan=0
[dosbox]
# language: Select another language file.
# machine: The type of machine DOSBox tries to emulate.
# Possible values: hercules, cga, cga_mono, tandy, pcjr, ega, vgaonly, svga_s3, svga_et3000, svga_et4000, svga_paradise, vesa_nolfb, vesa_oldvbe, amstrad.
# vmemsize: Amount of video memory in megabytes.
# The maximum resolution and color depth the svga_s3 will be able to display
# is determined by this value.
# 0: 512k (800x600 at 256 colors)
# 1: 1024x768 at 256 colors or 800x600 at 64k colors
# 2: 1600x1200 at 256 colors or 1024x768 at 64k colors or 640x480 at 16M colors
# 4: 1600x1200 at 64k colors or 1024x768 at 16M colors
# 8: up to 1600x1200 at 16M colors
# For build engine games, use more memory than in the list above so it can
# use triple buffering and thus won't flicker.
# captures: Directory where things like wave, midi, screenshot get captured.
# mainline compatible mapping: If set, arrange private areas, UMBs, and DOS kernel structures by default in the same way the mainline branch would do it.
# If cleared, these areas are allocated dynamically which may improve available memory and emulation accuracy.
# If your DOS game breaks under DOSBox-X but works with mainline DOSBox setting this option may help.
# adapter rom is ram: Map adapter ROM as RAM (mainline DOSBox 0.74 behavior). When clear, unused adapter ROM is mapped out
# private area size: Set DOSBox-X private memory area size. This area contains private memory structures used by the DOS kernel.
…Show last 513 lines
#                              It is discarded when you boot into another OS. Mainline DOSBox uses 32KB. Testing shows that it is possible
# to run DOSBox with as little as 4KB. If DOSBox-X aborts with error "not enough memory for internal tables"
# then you need to increase this value.
# memsize: Amount of memory DOSBox has in megabytes.
# This value is best left at its default to avoid problems with some games,
# though few games might require a higher value.
# There is generally no speed advantage when raising this value.
# memsizekb: Amount of memory DOSBox has in kilobytes.
# This value should normally be set to 0.
# If nonzero, overrides the memsize parameter.
# Finer grained control of total memory may be useful in
# emulating ancient DOS machines with less than 640KB of
# RAM or early 386 systems with odd extended memory sizes.
# memalias: Memory aliasing emulation, in number of valid address bits.
# . Many 386/486 class motherboards and processors prior to 1995
# suffered from memory aliasing for various technical reasons. If the software you are
# trying to run assumes aliasing, or otherwise plays cheap tricks with paging,
# enabling this option can help. Note that enabling this option can cause slight performance degredation. Set to 0 to disable.
# Recommended values when enabled:
# 24: 16MB aliasing. Common on 386SX systems (CPU had 24 external address bits)
# or 386DX and 486 systems where the CPU communicated directly with the ISA bus (A24-A31 tied off)
# 26: 64MB aliasing. Some 486s had only 26 external address bits, some motherboards tied off A26-A31
# vga bios size override: VGA BIOS size override. Override the size of the VGA BIOS (normally 32KB in compatible or 12KB in non-compatible).
# forcerate: Force the VGA framerate to a specific value(ntsc, pal, or specific hz), no matter what
# cgasnow: When machine=cga, determines whether or not to emulate CGA snow
# pit hack: If set, demo/game-specific hacks are applied to PIT timer emulation to help
# stabilize the demo and run more reliably. Valid values are:
# 'project_angel_demo' If you intend to run the Project Angel demo, use this
# setting. The PIT timer is forced to one of two values
# to resolve hangups, timing issues, music skipping on
# video mode changes, and VGA tearlines.
# 'pc_speaker_as_timer' A few early DOS demos apparently like to use PIT 2 as
# a timer source (where normally PIT 2 is used to generate
# a square wave to drive the PC speaker). If the demo you
# are running seems to run at half the normal speed for no
# logical reason, try this hack. Demos that need this hack:
# - Impact Studios, Legend
# Possible values: , project_angel_demo, pc_speaker_as_timer.
language=
machine=svga_s3
vmemsize=510
captures=capture
mainline compatible mapping=true
adapter rom is ram=false
private area size=32768
memsize=510
memsizekb=0
memalias=0
vga bios size override=0
forcerate=
cgasnow=true
pit hack=
[render]
# frameskip: How many frames DOSBox skips before drawing one.
# aspect: Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# linewise: Draw the display line by line. Needed for certain special graphics effects in games and demos. Can be changed at runtime but will be put in effect at the next mode switch.
# char9: Allow 9-pixel wide text mode fonts.
# doublescan: If set, doublescanned output emits two scanlines for each source line, in the
# same manner as the actual VGA output (320x200 is rendered as 640x400 for example).
# If clear, doublescanned output is rendered at the native source resolution (320x200 as 320x200).
# This affects the raster PRIOR to the software or hardware scalers. Choose wisely.
# scaler: Scaler used to enlarge/enhance low resolution modes. If 'forced' is appended,
# then the scaler will be used even if the result might not be desired.
# Possible values: none, normal2x, normal3x, normal4x, normal5x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x, hardware_none, hardware2x, hardware3x, hardware4x, hardware5x, xbrz.
# autofit: Best fits image to window
# - Intended for output=direct3d, fullresolution=original, aspect=true
frameskip=1
aspect=false
linewise=false
char9=false
doublescan=true
scaler=hardware2x
autofit=true
[vsync]
# vsyncmode: Synchronize vsync timing to the host display. Requires calibration within dosbox.
# Possible values: off, on, force, host.
# vsyncrate: Vsync rate used if vsync is enabled. Ignored if vsyncmode is set to host (win32).
# Possible values:.
vsyncmode=off
vsyncrate=75
[cpu]
# core: CPU Core used in emulation. auto will switch to dynamic if available and
# appropriate.
# Possible values: auto, dynamic, normal, full, simple.
# cputype: CPU Type used in emulation. auto emulates a 486 which tolerates Pentium instructions.
# Possible values: auto, 386, 486, pentium, 386_prefetch, pentium_mmx.
# cycles: Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# Cycles can be set in 3 ways:
# 'auto' tries to guess what a game needs.
# It usually works, but can fail for certain games.
# 'fixed #number' will set a fixed amount of cycles. This is what you usually
# need if 'auto' fails (Example: fixed 4000).
# 'max' will allocate as much cycles as your computer is able to
# handle.
# Possible values: auto, fixed, max.
# cycleup: Amount of cycles to decrease/increase with keycombos.(CTRL-F11/CTRL-F12)
# cycledown: Setting it lower than 100 will be a percentage.
# ignore opcode 63: When debugging, do not report illegal opcode 0x63.
# Enable this option to ignore spurious errors while debugging from within Windows 3.1/9x/ME
# apmbios: Emulate Advanced Power Management BIOS calls.
# Do not enable if you are running Windows ME.
# isapnpbios: Emulate ISA Plug & Play BIOS. Enable if using DOSBox to run a PnP aware DOS program or if booting Windows 9x.
# Do not disable if Windows 9x is configured around PnP devices, you will likely confuse it.
# realbig16: Allow the B (big) bit in real mode. If set, allow the DOS program to set the B bit,
# then jump to realmode with B still set (aka Huge Unreal mode). Needed for Project Angel.
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
ignore opcode 63=true
apmbios=false
isapnpbios=true
realbig16=false
[keyboard]
# aux: Enable emulation of the 8042 auxiliary port. PS/2 mouse emulation requires this to be enabled.
# You should enable this if you will be running Windows ME or any other OS that does not use the BIOS to receive mouse events.
# auxdevice: Type of PS/2 mouse attached to the AUX port
# Possible values: none, 2button, 3button, intellimouse, intellimouse45.
aux=false
auxdevice=intellimouse
[pci]
# voodoo: Enable VOODOO support.
# Possible values: false, software, opengl, auto.
voodoo=auto
[mixer]
# nosound: Enable silent mode, sound is still emulated though.
# swapstereo: Swaps the left and right stereo channels.
# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
# Possible values: 1024, 2048, 4096, 8192, 512, 256.
# prebuffer: How many milliseconds of data to keep on top of the blocksize.
nosound=false
swapstereo=false
rate=49716
blocksize=1024
prebuffer=20
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, mt32, synth, timidity, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
# or in the case of coreaudio, you can specify a soundfont here.
# When using a Roland MT-32 rev. 0 as midi output device, some games may require a delay in order to prevent 'buffer overflow' issues.
# In that case, add 'delaysysex', for example: midiconfig=2 delaysysex
# See the README/Manual for more details.
# mt32.reverse.stereo: Reverse stereo channels for MT-32 output
# Possible values: off, on.
# mt32.verbose: MT-32 debug logging
# mt32.thread: MT-32 rendering in separate thread
# mt32.dac: MT-32 DAC input emulation mode
# Nice = 0 - default
# Produces samples at double the volume, without tricks.
# Higher quality than the real devices
# Pure = 1
# Produces samples that exactly match the bits output from the emulated LA32.
# Nicer overdrive characteristics than the DAC hacks (it simply clips samples within range)
# Much less likely to overdrive than any other mode.
# Half the volume of any of the other modes, meaning its volume relative to the reverb
# output when mixed together directly will sound wrong. So, reverb level must be lowered.
# Perfect for developers while debugging :)
# GENERATION1 = 2
# Re-orders the LA32 output bits as in early generation MT-32s (according to Wikipedia).
# Bit order at DAC (where each number represents the original LA32 output bit number, and XX means the bit is always low):
# 15 13 12 11 10 09 08 07 06 05 04 03 02 01 00 XX
# GENERATION2 = 3
# Re-orders the LA32 output bits as in later geneerations (personally confirmed on my CM-32L - KG).
# Bit order at DAC (where each number represents the original LA32 output bit number):
# 15 13 12 11 10 09 08 07 06 05 04 03 02 01 00 14
# Possible values: 0, 1, 2, 3, auto.
# mt32.reverb.mode: MT-32 reverb mode
# mt32.reverb.time: MT-32 reverb decaying time
# Possible values: 0, 1, 2, 3, 4, 5, 6, 7.
# mt32.reverb.level: MT-32 reverb level
# mt32.partials: MT-32 max partials allowed (0-256)
mpu401=intelligent
mididevice=default
midiconfig=0
mt32.reverse.stereo=off
mt32.verbose=off
mt32.thread=off
mt32.dac=auto
mt32.reverb.mode=auto
mt32.reverb.time=5
mt32.reverb.level=3
mt32.partials=32
[sblaster]
# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, sb16vibra, gb, none.
# sbbase: The IO address of the soundblaster.
# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
# irq: The IRQ number of the soundblaster.
# Possible values: 7, 5, 3, 9, 10, 11, 12.
# dma: The DMA number of the soundblaster.
# Possible values: 1, 5, 0, 3, 6, 7.
# hdma: The High DMA number of the soundblaster.
# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type.
# All OPL modes are Adlib-compatible, except for 'cms'. sbtype=none
# together with oplmode=cms will emulate a Gameblaster.
# Possible values: auto, cms, opl2, dualopl2, opl3, none, hardware, hardwaregb.
# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
# Possible values: default, compat, fast.
# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
# hardwarebase: base address of the real hardware soundblaster:
# 210,220,230,240,250,260,280
# goldplay: Enable goldplay emulation.
sbtype=sb1
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=compat
oplemu=default
oplrate=44100
hardwarebase=220
goldplay=true
[gus]
# gus: Enable the Gravis Ultrasound emulation.
# gusrate: Sample rate of Ultrasound emulation.
# gusbase: The IO base address of the Gravis Ultrasound.
# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
# gusirq: The IRQ number of the Gravis Ultrasound.
# Possible values: 5, 3, 7, 9, 10, 11, 12.
# gusdma: The DMA channel of the Gravis Ultrasound.
# Possible values: 3, 0, 1, 5, 6, 7.
# ultradir: Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
gusrate=49716
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASNDPPL161
[innova]
# innova: Enable the Innovation SSI-2001 emulation.
# samplerate: Sample rate of Innovation SSI-2001 emulation
# sidbase: SID base port (typically 280h).
# quality: Set SID emulation quality level (0 to 3).
# Possible values: 0, 1, 2, 3.
innova=true
samplerate=49716
sidbase=280
quality=0
[speaker]
# pcspeaker: Enable PC-Speaker emulation.
# pcrate: Sample rate of the PC-Speaker sound generation.
# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
# Possible values: auto, on, off.
# tandyrate: Sample rate of the Tandy 3-Voice generation.
# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
# ps1audio: Enable PS1 audio emulation.
# Possible values: on, off.
# ps1audiorate: Sample rate of the PS1 audio emulation.
pcspeaker=true
pcrate=49716
tandy=on
tandyrate=49716
disney=true
ps1audio=on
ps1audiorate=49716
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
# serial1: set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq (optional).
# for directserial: realport (required), rxdelay (optional).
# (realport:COM1 realport:ttyS0).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
# Possible values: dummy, disabled, modem, nullmodem, serialmouse, directserial.
# serial2: see serial1
# serial3: see serial1
# serial4: see serial1
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[printer]
# printer: Enable printer emulation.
# dpi: Resolution of printer (default 360).
# width: Width of paper in 1/10 inch (default 85 = 8.5'').
# height: Height of paper in 1/10 inch (default 110 = 11.0'').
# printoutput: Output method for finished pages:
# png : Creates PNG images (default)
# ps : Creates Postscript
# bmp : Creates BMP images (very huge files, not recommend)
# printer : Send to an actual printer (Print dialog will appear)
# multipage: Adds all pages to one Postscript file or printer job until CTRL-F2 is pressed.
# docpath: The path where the output files are stored.
# timeout: (in milliseconds) if nonzero: the time the page will
# be ejected automatically after when no more data
# arrives at the printer.
printer=true
dpi=360
width=85
height=110
printoutput=png
multipage=false
docpath=.
timeout=0
[parallel]
# parallel1: parallel1-3 -- set type of device connected to lpt port.
# Can be:
# reallpt (direct parallel port passthrough),
# file (records data to a file or passes it to a device),
# printer (virtual dot-matrix printer, see [printer] section)
# parameter:value.
# for reallpt:
# Windows:
# realbase (the base address of your real parallel port).
# Default: 378
# ecpbase (base address of the ECP registers, optional).
# Linux: realport (the parallel port device i.e. /dev/parport0).
# for file:
# dev:<devname> (i.e. dev:lpt1) to forward data to a device,
# or append:<file> appends data to the specified file.
# Without the above parameters data is written to files in the capture dir.
# Additional parameters: timeout:<milliseconds> = how long to wait before
# closing the file on inactivity (default:500), addFF to add a formfeed when
# closing, addLF to add a linefeed if the app doesn't, cp:<codepage number>
# to perform codepage translation, i.e. cp:437
# for printer:
# printer still has it's own configuration section above.
# parallel2: see parallel1
# parallel3: see parallel1
# dongle: Enable dongle
parallel1=disabled
parallel2=disabled
parallel3=disabled
dongle=false
[glide]
# glide: Enable glide emulation: true,false,emu.
# lfb: LFB access: full,full_noaux,read,read_noaux,write,write_noaux,none.
# OpenGlide does not support locking aux buffer, please use _noaux modes.
# splash: Show 3dfx splash screen (requires 3dfxSpl2.dll).
glide=true
lfb=full
splash=true
[dos]
# xms: Enable XMS support.
# ems: Enable EMS support. The default (=true) provides the best
# compatibility but certain applications may run better with
# other choices, or require EMS support to be disabled (=false)
# to work at all.
# Possible values: true, emsboard, emm386, false.
# umb: Enable UMB support.
# umb start: UMB region starting segment
# umb end: UMB region last segment
# dynamic kernel allocation: If set, DOS kernel structures are allocated dynamically. If clear, DOS kernel structures are fixed at specific segments (mainline DOSBox behavior)
# keep umb on boot: If emulating UMBs, keep the UMB around after boot (Mainline DOSBox behavior). If clear, UMB is unmapped when you boot an operating system.
# keep private area on boot: If set, keep the DOSBox private area around after boot (Mainline DOSBox behavior). If clear, unmap and discard the private area when you boot an operating system.
# private area in umb: If set, keep private DOS segment in upper memory block, usually segment 0xC800 (Mainline DOSBox behavior)
# If clear, place private DOS segment at the base of system memory (just below the MCB)
# automount: Enable automatic mount.
# int33: Enable INT 33H (mouse) support.
# biosps2: Emulate BIOS INT 15h PS/2 mouse services
# Note that some OS's like Microsoft Windows neither use INT 33h nor
# probe the AUX port directly and depend on this BIOS interface exclusively
# for PS/2 mouse support. In other cases there is no harm in leaving this enabled
# keyboardlayout: Language code of the keyboard layout (or none).
# dbcs: Enable DBCS table
# filenamechar: Enable filename char table
# collating and uppercase: Enable collating and uppercase table
# files: Number of file handles available to DOS programs. (equivalent to "files=" in config.sys)
xms=true
ems=true
umb=true
umb start=0
umb end=0
dynamic kernel allocation=false
keep umb on boot=false
keep private area on boot=false
private area in umb=true
automount=true
int33=true
biosps2=true
keyboardlayout=en
dbcs=true
filenamechar=true
collating and uppercase=true
files=127
[ipx]
# ipx: Enable ipx over UDP/IP emulation.
ipx=false
[ne2000]
# ne2000: Enable Ethernet passthrough. Requires [Win]Pcap.
# nicbase: The base address of the NE2000 board.
# nicirq: The interrupt it uses. Note serial2 uses IRQ3 as default.
# macaddr: The physical address the emulator will use on your network.
# If you have multiple DOSBoxes running on your network,
# this has to be changed for each. AC:DE:48 is an address range reserved for
# private use, so modify the last three number blocks.
# I.e. AC:DE:48:88:99:AB.
# realnic: Specifies which of your network interfaces is used.
# Write 'list' here to see the list of devices in the
# Status Window. Then make your choice and put either the
# interface number (2 or something) or a part of your adapters
# name, e.g. VIA here.
ne2000=true
nicbase=300
nicirq=3
macaddr=AC:DE:48:88:99:AA
realnic=list
[ide, primary]
# enable: Enable IDE interface
# int13fakeio: If set, force IDE state change on certain INT 13h commands.
# IDE registers will be changed as if BIOS had carried out the action.
# If you are running Windows 3.11 or Windows 3.11 Windows for Workgroups
# you must enable this option (and use -reservecyl 1) if you want 32-bit
# disk access to work correctly in DOSBox.
# int13fakev86io: If set, and int13fakeio is set, certain INT 13h commands will
# cause IDE emulation to issue fake CPU I/O traps (GPF) in
# virtual 8086 mode and a fake IRQ signal. you must enable this option
# if you want 32-bit disk access in Windows 95 to work with DOSBox.
enable=true
int13fakeio=false
int13fakev86io=false
[ide, secondary]
enable=true
int13fakeio=false
[ide, tertiary]
enable=true
int13fakeio=false
[ide, quaternary]
enable=true
int13fakeio=false
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
mount C E:\Giochi\DOS\
mount D M:\ -t cdrom
C:
dir /w/p
Before you ask, that happens with both DOSBox 0.74 and DOSBox SVN-Daum, which is the version I use the most due to the "maximized window" option.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 1 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
increase the cycles.(blakestone)
Water flows down the stream
Reply 2 of 19, by Elia1995
I just tested Blake Stone with max cycles and, even though most of the game looks smooth at 60 FPS, it drops the framerate whenever I pick up something 😒
Reply 3 of 19, by collector
ALT+Enter is too much work to switch between windowed and full screen?
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 4 of 19, by Elia1995
Well, it doesn't make any performance difference between the two versions anyway 😁
And by the way, in SVN-Daum version, you can just "maximize" it while keeping it windowed, not full screen, since I have 2 monitors here on my main computer, that makes a huge difference for me, since there's no "borderless" option 🤣
Reply 6 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
Try a different value from max
Maybe 10000 or so
Although be aware that it might be part of the game.
Reply 7 of 19, by Elia1995
Nope, it doesn't do that normally.
By the way, just using D-Fend Reloaded as DOSBox frontend, fixed it with Blake Stone.
Blupimania is still unplayable, tho 😢
Reply 8 of 19, by Tertz
Have tried "Blupimania" shareware in DB 0.74 on all default settings. The SB was cofigured by setup.exe. The game works ok. Rising of cycles to >6000 makes the game run better.
Try to reset to defaults, then:
core=normal
cputype=486_slow
cycles=10000
For fullscreen mode may be tried:
fulldouble=true
also may be useful other settings for
output=
machine=
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 9 of 19, by ripa
Most DOS games render at 70 Hz, while most computer monitors nowdays are fixed at 60 Hz, so v-sync functionality may cause Dosbox to be slowed down. Try frameskip=1, which will drop 70 Hz down to 35 Hz.
Reply 10 of 19, by Tertz
He said that has issues in 0.74 which has no vsync option and default surface mode has no relation to vsync in D3D/OGL. The game on default settings of 0.74 works goodly with 60 Hz.
Yamaha YMF7x4 Guide
Reply 11 of 19, by Elia1995
Even though increasing the CPU cycles makes the games a bit faster, they look still quite choppy for me, compared to how fine and smooth they play on my Intel Celeron 1.10 GHz MS-DOS 7.10 computer.
Reply 12 of 19, by Tertz
Play in window, not fullscreen for testing.
What are your CPU, MB, video card and OS?
DOSBox regulates internal speed depending on system's performance. If CPU's speed jumps, then this may result in lugging. Thus may be tried something.
Try to remove background processes like antivirus, net connections, etc.
Check is CPU officially supported by MB, BIOS is newest and chipset driver is fresh. Try to disable energy saving for CPU in BIOS. Disable hyper-threading. Set higher allowed TDP limits and lower CPU clock.
Assign to DB higher priority= in config. If it's possible assign DB to run strictly on single core.
Try to disable sound in game's settings to exclude IRQ sharing issue.
Yamaha YMF7x4 Guide
Reply 13 of 19, by ripa
I didn't mean any Dosbox built-in v-sync. There may be something like activated in the OS graphics stack. Dosbox performance depends very much on the OS, graphics card, drivers, and config settings.
edit: SDL 1.x's "default surface mode" on Windows is implemented on WinDIB or some ancient DirectDraw (selected by SDL_VIDEO_DRIVER). I'm 90% sure those are implemented with some compatibility layer on modern Windows, so it's feasible that the graphics stack may enforce v-sync.
Reply 14 of 19, by Tertz
It depends significantly only on CPU, except pre-P4. As for config, to use default settings for 0.74 was recommended to him and seems did not help. Other stuttering is related to bugs, wrong using of hardware, etc. Wrong power management settings are the most suspicious.
In case Win10 had vsync issue in DB with his problems, the forum would flooded with complains.
Yamaha YMF7x4 Guide
Reply 15 of 19, by Elia1995
The strange thing is that by using a front-end such as D-Fend Reloaded, they look just fine, the problem is when I try to use "raw" DOSBox...
Reply 16 of 19, by Jorpho
There's probably some difference in the configurations. If you can exit the game and get to a command prompt in D-Fend Reloaded, you can use the CONFIG command to write the configuration to a file, and then compare it with the config you're using for "'raw' DOSBox".
Reply 17 of 19, by Tertz
"Blupimania is still unplayable" - this was about using D-Fend. Anyway, as you don't give imortant information about your system, it's impossible to help you. As for Blake Stone - the only "strange" thing D-Fend does is using own settings for the emulator.
Yamaha YMF7x4 Guide
Reply 18 of 19, by Elia1995
My CPU is an Intel i7-4790K 4.00GHz not overclocked (yet)
I also have 16 GB DDR3 of RAM and a GTX 970 as graphics card, these are the 3 most important informations about my main PC.
Anyway I'm probably going to reinstall 7 in a few days, I'll take the chance to check if DOSBox will perform better in a fresh installed Windows 7 😁
Reply 19 of 19, by ripa
You might be right that with default settings, v-sync is not an issue, but I don't have (and don't intend to have) Win10 to check this with.
But you're wrong about computer config not affecting Dosbox performance. I remember you have mentioned that you're not a programmer, so I'll explain this in simple terms.
- With output=surface, Dosbox uses SDL's video API (e.g., SDL_BlitSurface, SDL_Flip).
- If the game is using 70 Hz refresh rate and the screen contents are changing every frame (e.g., palette animation fades), Dosbox is updating the screen 70 times per second using that API.
- SDL in turn uses directx5 (or WinDib) API to implement the video API on Windows.
- Here's what you find in SDL DX5_FlipHWSurface, for example:
while(IDirectDrawSurface3_GetFlipStatus(dd_surface, DDGBS_ISBLTDONE) == DDERR_WASSTILLDRAWING);
- So that function will block until graphics driver has finished drawing (i.e., you can't call it faster than screen refresh rate without blocking if there's some kind of v-sync feature / implementation active in the graphics driver).
- Even without that busy-wait loop, directdraw functions like blitting, locking and/or flipping may block if the surface is not available - I've tested and profiled this.
- 60 Hz display refresh rate corresponds to ~17 milliseconds, which is basically the worst case time those functions can block.
- Dosbox operates in 1 millisecond "frames" with some specific emulated cycles / frame
- If cycles auto-adjustment is active (cycles=auto and game is using protected mode or user has set cycles=max or some percentage), Dosbox measures the real time it takes to emulate a frame.
- If Dosbox detects that it is late (i.e., emulating one frame takes too long), Dosbox reduces the number of emulated cycles/frame (the control is a bit more complicated than this but you get the point).
- Graphics output functions blocking for several milliseconds will thus make Dosbox detect that it is very late, reducing the cycles/frame. It will also cause sound skipping.
- The rate of graphics output function calls is not reduced (it stays at 70 Hz), so reducing cycles will not reduce the amount of blocking.
- The end result is that Dosbox auto-reduces the cycles/frame to very low and spends an increasing proportion of CPU time spin-waiting in the graphics functions, making the game very slow.
- Easy fix is to use frameskip=1 to reduce refresh rate to half.
- I've implemented some workarounds to get Dosbox to skip rendering if it detects/guesses that the graphics output will block. This actually seems to work and gives smoother output than frameskip=1. See Re: DOSBox over S-Video TV-Out stuttering/jerkiness
- Because Dosbox does not update the screen at maximum refresh rate if the screen contents don't change, this effect is only noticeable in games that actually render something at 70 Hz.
