Sound Blaster CT4750 sounds like garbage in DOS games...
First post, by Elia1995
Hi, so I've been playing with my "new" Windows 98 PC these days and I've also tried several DOS games (mostly from Apogee, because that's what recalls my childhood the most) but... I've noticed that the audio is there, but it sounds like crap !!!
I mean, I know I can't expect AWE32 goodness off a PCI128 CT4750, but why do sound effects and AdLib music sound horrible ? The music on most games is like "out of tune", the sound effects make weird noises... if I can
Here's the video for the brave ones who are so corageous to listen to them, I tested DN3D, Blake Stone and Commander Keen 4 (the last one has glitches even in SOUND EFFECTS other than just music like the other ones).
http://www.youtube.com/watch?v=xD42SeYVTe0 (I dunno how to embed it...)
So far I tried:
Duke Nukem 3D: Adlib music sounds way out of tune, expecially the "melody" part of the theme song.
Blood: same as Duke Nukem 3D, but much less noticeable (sounds better to the ear, but obviously not as good as it should be)
Commander Keen, excluding the first 3 for obvious reasons, sounds quite bad, both sound effects and music. The sound effects sound like they're made by a drunken sound artist or something like that 😐
Bio Menace: the music sounds good, except Skullman's theme and the sound effects are strangely almost perfect.
Duke Nukem 2 sounds... just awful.
I can hear major distortion in almost any "Apogee" intro music, except Monster Bash which refuses to start (it says I don't have enough conventional memory or something like that 😒 )
All of them work and sound perfect on the Intel Celeron DOS PC, so I could just "go and play them over there or DOSBox", but since Windows 98 supports DOS games, why not work hard and make them work aswell ? 😕
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 1 of 67, by brostenen
SB-128 are not for Dos games. You need something else that has real OPL on it.
Nothing is wrong with the 128, as such, it is just the wrong card for any Dos-OPL games.
Reply 2 of 67, by Elia1995
Hmmm I see... and is there no way to emulate OPL in DOS games with Windows 98, such as VDMSound ?
Reply 3 of 67, by keenmaster486
Depending on the specs of your machine you'll be able to run DOSBox on it, but that kind of defeats the purpose.
Some of those games support MIDI music as well, you could try that. But I didn't think music and effects would sound as bad as you're describing, even with the crappiest PCI card... yes, some recordings would be nice.
World's foremost 486 enjoyer.
Reply 4 of 67, by Elia1995
Ok, I'm editing the video now, will upload soon.
Reply 5 of 67, by jesolo
If your PC still has an available ISA slot, then I would rather swop out the PCI card for an OLP3 based ISA card, especially if you intend on playing old DOS games using FM synthesis for music playback.
There are some PCI sound cards (with the Yamaha YMF7xx chipset) that has OPL3 synthesis built into the chip.
Personally, when it comes to playing DOS games, I stay away from PCI sound cards.
Reply 6 of 67, by PhilsComputerLab
Isn't that a Audio PCI type card? Those just used the wavetable for FM, really bad.
YouTube, Facebook, Website
Reply 7 of 67, by Elia1995
The ASUS A8V-XE, which is the motherboard I used to make this Windows 98 PC, doesn't have any ISA slot, unfortunately 😢
I wonder if some kind of "adapter" (PCI to ISA) exists... but no way I'm gonna remove my beloved CT3670 from the DOS PC to put it in there, I'll probably add the Sound Blaster CT29xx (forgot the last 2 digits) I put in the 486 PC.
Reply 8 of 67, by brostenen
They do, yet they are really expensive and there is no guarantee that it will work.
I would say, looking at the spec's, to get and Vortex or an YMF-724.
Reply 9 of 67, by keenmaster486
Wow... that's the weirdest music I've ever heard.
From the sound of it and what people were saying earlier it might be trying to use the wavetable to emulate OPL synthesis. Weird. Yeah, I would get a different card, even a lot of cheap PCI cards from early 2000's I think have some kind of FM synthesis chip. I have a Turtle Beach Riviera which works great in DOS for OPL music.
And Keen 4 is the only one that has weirded out sound effects because, I think, it's the only one that you tested that doesn't use digital sound effects. It actually has one FM channel set aside for effects.
Reply 10 of 67, by Jorpho
As discussed in one of your other threads, you might get better music if you load one of the other ECW wavesets. (It's something I've been meaning to test further myself one of these days.)
Reply 11 of 67, by Elia1995
I only have 2MB, 4MB and 8MB ECW wavesets in my system folder, can I load .sf2 soundfonts somehow or get some better ECW files ?
Reply 12 of 67, by Jorpho
Exactly. Have you tried them? I understand they sound substantially different.
No, you can't load .sf2 soundfonts without an SB Live (EDIT: or an AWE32/64 with enough onboard RAM), and I don't think anyone ever made new ECW sets. (I vaguely recall reading that someone did get around to reverse-engineering the format, but that was a long time ago.)
See also http://www.flaterco.com/kb/audio/PCI/ , which suggests that the Ensoniq synth can be skipped as long as you're running Windows.
Reply 13 of 67, by Tertz
Then no way to get good FM, as your "beloved" is based on shitty CQM.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 14 of 67, by keenmaster486
Ho ho, did you listen to his YouTube video? It makes CQM sound like heaven in comparison. But of course nothing sounds as good as a real OPL3 chip.
Reply 15 of 67, by Tertz
CQM may sound too wrong sometimes to think it as acceptable OPL replace. While there are accessible SB16 cards with 262/CT1747/289 and YMF cards. So to use CQM is senseless if you are interested in authentic hardware.
Yamaha YMF7x4 Guide
Reply 16 of 67, by Elia1995
The CT3670 is the only AWE32 capable sound card I have for my DOS machine at the moment 😐
Reply 17 of 67, by PhilsComputerLab
That's exactly what it does 😊
Reply 18 of 67, by brostenen
When thinking about it, it kind of sounds a bit like the pc is trying to feed the card too fast.
Can something like that ever happen?
Reply 19 of 67, by Elia1995
Doom's E1M1 actually sounds quite epic imho...
I actually like the drums in there
I didn't try it yesterday 🤣
