Reply 11921 of 52814, by kithylin
brostenen wrote:
Look's like a lot of work is going in that case, if the reddish stuff is rust.
Take apart, sandblow and repaint....
I can tell, that's definitely rust. Besides that.. that old server case there looks like it uses non-standard and unique some sort of plastic rails or metal rails that go on the side of the 5.25" devices.. and likely can't even mount a cd-rom without those. And they're likely lost to time now.
Reply 11923 of 52814, by senrew
Wife insisted we go hunting today. Hit up a bunch of thrifts and pawn shops, but managed to come back with this:
http://imgur.com/a/ob84O
The relevant parts here are the laptop and the G4 tower. The Apple is G4/466 "Digital Audio". Seems to be bone stock, but needs a good cleaning.
The more interesting thing is the laptop. Found it at a pawn shop for $9.00 since they didn't have the AC adapter. Figured if nothing else I could use it as a parts donor for my other Latitude. It uses the same adapter so I plugged it in and BAM, works perfectly.
Dell C610, 1ghz, 16MB VRAM
Still doing some research on it, but it seems to be a recommended machine around here for laptop gaming of the era.
The G4 came out to $30 even.
Halcyon: PC Chips M525, P100, 64MB, Millenium 1, Voodoo1, AWE64, DVD, Win95B
Reply 11924 of 52814, by kithylin
senrew wrote:
Wife insisted we go hunting today. Hit up a bunch of thrifts and pawn shops, but managed to come back with this: http://imgur.co […]
The C610's can take up to 1.3 ghz mobile 512KB cached P3 Tualatin and usually come with a GeForce2 Go mobile card up to 32MB or 64 MB, which are actually quite confident for early Win9x gaming, and have quite speedy ms-dos acceleration for VESA game modes. Also you can use the same multi-bay devices from the older 500 series lattitudes (direct compatible) and if you fit em with 2 healthy lithium ion cells they alternate between batteries and sometimes run 8-12 hours on full charge. At least mine did when I had it years ago. I bought one recently but it's got a dead screen and I dunno yet if I want to repair it or not. The mobile P3's there even have a very early version of Intel SpeedStep and will shift down to half speed in windows if you're idle.
Reply 11925 of 52814, by senrew
kithylin wrote:
The C610's can take up to 1.3 ghz mobile 512KB cached P3 Tulatiains and usually come with a GeForce2 Go mobile card up to 32MB or 64 MB, which are actually quite confident for early Win9x gaming, and have quite speedy ms-dos acceleration for VESA game modes. Also you can use the same multi-bay devices from the older 500 series lattitudes (direct compatible) and if you fit em with 2 healthy lithium ion cells they alternate between batteries and sometimes run 8-12 hours on full charge. At least mine did when I had it years ago. I bought one recently but it's got a dead screen and I dunno yet if I want to repair it or not.
The screen hinges on this one are weak. Not much past vertical and it falls back easily. Looks like 1ghz/700mhz for AC/Battery. Mobility Radeon 16MB (Guessing that's VE equivalent? MP6?), and whatever this Crystal 4205 sound is.
My older machine is a CPx 500hgt something or other. It's got the combo DVD reader/CD Burner drive, floppy, but dead battery. However, the rest of the hardware is virtually brand new. May do some frankensteining to combine them into the newer machine if I can. I'll be looking into the upgrade parts now. 😀
Reply 11926 of 52814, by Lukeno94
The C600 hinges are a notorious weak point, and I can't imagine they changed them on the C610. The right hinge IIRC (the one with the two parts) is very prone to metal fatigue and shearing off, as I've seen on multiple examples - and many of the ones on eBay have this issue. At least the C610 won't suffer from the hideously high heat output that my 1 GHz Coppermine C600 did... that was just ridiculous. Coppermine 1 GHz laptop CPUs are a terrible thing, worse than most P4s.
Parts for the C610 are plentiful, and I'd imagine everything from the C600 (bar CPUs and possibly GPUs) and many things from the C640 will fit perfectly. Parts from the Inspiron 4000 and 4100 should also fit perfectly, as they're direct clones of the C600/C610; maybe parts from the C640 clones (2650 and 4150) will fit as well. The Dell Modular Bay things will fit your CPx fine, but otherwise the only things likely to be compatible are the RAM and HDD - even the Coppermine CPU uses a different connector to the Tulatin ones (not to mention that putting a 1 GHz CPU in a system originally designed for Pentium MMXs may not be the best idea). Replacement Dell Modular Bay batteries are only about £15 on eBay if you get one from Hong Kong.
Reply 11927 of 52814, by CHiLL72
Bought this http://www.ebay.com/itm/361553783245?_trksid= … K%3AMEBIDX%3AIT this morning...
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 11928 of 52814, by easy_john
Awesome!
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 11929 of 52814, by brostenen
Got in the mail today, one I/O-Shield for my P3 motherboard.
Reply 11930 of 52814, by bjt
A colleague gave me this, might try it in my Socket 7 machine. Can't see it being a longterm replacement for the GF2 PCI though as I hear that it's super slow in 320x200 DOS games.
Reply 11931 of 52814, by MrEWhite
bjt wrote:
A colleague gave me this, might try it in my Socket 7 machine. Can't see it being a longterm replacement for the GF2 PCI though […]
Yeah, the 2D sucks on it.
Reply 11932 of 52814, by devius
But it has a pretty logo in the chip so that should make up for the slowness 😀
Reply 11933 of 52814, by Bancho
This arrived today. £6.68 + Postage. Gainward 6800 Ultra 256mb. Arrived in a jiffy bag, which the postman tried to push through the letterbox 🤣. Fortunately i was there to stop him. Can't believe how people treat things they sell to people. Card was filthy too. Popped it into my test machine and it works and i will give it a good clean later.
Reply 11934 of 52814, by jheronimus
senrew wrote:
Wife insisted we go hunting today. Hit up a bunch of thrifts and pawn shops.
Kudos to your wife! What does she get out of thrifting?
MR BIOS catalog
Unicore catalog
Reply 11936 of 52814, by senrew
She's always on the lookout for musical equipment. For example, if I'm looking for a roland module for gaming, she's looking for almost the same roland gear for her home studio. Both sides of the same (expensive!) coin. Euro House/Dance/Club CDs from 80s/90s, Synthpop anything. Occasionally she'll spot some clothes or something she likes. I'm the one who comes home with the bulky unnecessary electronics and other such items.
Reply 11937 of 52814, by firev12
Hello, long time lurker. I am building a 486 (DX 40 MHz, like my 1st PC). I recently bought the m/b you see. Can anyone identify it? On the back side there is a "486IG-B-2-1" printed, along with "P103". Can't test it yet, no ISA VGA available. Another issue, I tried to pull the CPU (from the heatsink) but I can't remove it. Do I need any special tool?
    229.61 KiB
Reply 11939 of 52814, by PeterLI
I find shopping in thrift stores to a big waste of time here in FL. Most square footage inside the stores is dedicated to clothing. The electronics racks are usually very small and have DVD/CD players plus kitchen equipment. Recently on a (rare) spare afternoon I dropped by 8 thrift / pawn stores and found 2 LaserDisc movies: that was all. 🤣
And I included Goodwill, Salvation Army and small / mid size pawn shops. Pawn shops are the biggest waste of time because they charge crazy amounts for generic junk like CD / DVD players.
