First post, by Splinter
Last week a customer brought his gaming machine into the shop as a small fire had taken place inside the machine which turned out to be a molex/sata adaptor cable running to the DVD.
Over the years I've used loads of these cables but only when it's the only solution and you simply don't have any more sata connectors left on the PSU as this has happened before.
On this occasion though, the machine had been built elsewhere, but all the same, it could have been disastrous and only needed a new DVD.
Cleaning up the machine after his dad used the fire extinguisher on it, took 2 days of dismantling, cleaning and reassembly which was more fun than it sounds actually.
Here's some evidence.
http://www.compufixshop.com
Main rig Ryzen 2600X Strix RX580 32GB RAM
Secondary rig FX8350 GTX960 16GB RAM
Reply 1 of 7, by brostenen
Speaking of meltdown. 😁
Reply 2 of 7, by 133MHz
Ouch, I'd say that it looks like the 12V rail passed some serious current through there, but then it'd have triggered the OCP on the PSU - so it probably shorted just enough to overheat and catch fire but not so much as to cause a shutdown.
I've had crappy PSUs with their molex pins protruding too much out of the plastic shell brush against the sides or bottom of the case, causing sparks and shutdowns/reboots, but no meltdowns/fires yet.
http://133FSB.wordpress.com
Reply 3 of 7, by Splinter
The other time it happened was on a brand new 3Tb hard drive which miraculously survived as the connectors on the drive didn't melt and it continued to work for about three years and then died.
I'm not sure if i ever want to use these adaptors ever again.
Reply 4 of 7, by Davros
I see the water cooling didnt help with the fire 😁
Reply 5 of 7, by RogueTrip2012
I don't see any arcing on the end of the sata connector so I bet it internally started arcing and then lit up. Maybe a bad plastic molding on the sata connector side?!
Was the cable pulled tight in the when installed? could of cause extra pressure to the molding.
It probably wasn't enough of a short to trip the Over current protect on the PSU to shutdown.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 6 of 7, by Jade Falcon
Rank BANNED
BANNED
old post
Reply 7 of 7, by Kodai
It looks like there is/was a bit of electrical tape on the adaptor. Was it a home made adaptor? Of the hundreds of Molex to SATA adaptors I've used over the years, only a few have ever failed and none have burned up. The few that failed were either pulled apart in there packages, or fell apart (at the Molex end) when being plugged in. I'd say that what you got is a really rare, odd ball occurrence if it was a commercially bought adaptor.
