First post, by nagi
Hi everybody,
dont know if this is the right area, but I just wanted to let you know of a bug in DosBox 0.63 which I discovered using QuickBasic:
the following line will produce incorrect results:
AT# = VAL( AT$)
eg: if AT$="05", VAL will convert it to 4.999999999999999
whereas it should be 5.000...
Hope you can fix this soon
and by the way, excellent job DosBox is cool
